I need to create some trace logs for a call loop that is happening between two clusters via non-gatekeeper controlled Intercluster trunk. Can anyone recommend a best trace is best for this? This is on CUCM 8.0.
Hi,On our PoE switch, IP phones reboot many times during the day. I checked the switch. It did not reboot.Is there a way to verify power consumption by phones on the switch? thanks
I would like to upgrade a 7962G to a more updated firmware version. I am not able to find documentation on how to upload the file to CUCM 7.1 and perform the upgrade only to one or two phones, before deploying the new firmware to rest of the phones....
All -I'm 90% sure I already know the answer on this one, but I wanted to send out a quick email to check anyway.I have a customer who is planning to roll out color phones to everyone in the company. I have been provided with a customized wallpaper f...
Hi,Talking about them, its only needed that be at least two USB Tokens to implement the CTL file? Must they be compliant with any specification to match any CUCM release ??Thaks in advance.Gerardo Fajardo
Hi,Need to write tcl and vxml script to work with IOSNeed to play with BACD & CVPTried to google for vxml and tcl is good. But if there is a specific guides on Cisco for these topics will be appreciatedRegards
We had the version of CUCM 7.1.5.10000-12, which was affected by the bug CSCtg96124 which consumed 4 DLU for phone models 6921, after an upgrade to 7.1.5.33900-10, the 6921 consumes 2 DLU.Anyone know if the DLU consumed was reduced to 6921 from 3 to ...
Check and correct disk file systems.. how long should this take?7828 h3 2 250gig HD
Hello,I am having a problem when importing subscribers using Cisco Unity Bulk Import wizard the following error occurs in the error log file:“(Error) Sync failed: Joe.Smith. Error: LDAP_INSUFFICIENT_RIGHTSThe Cisco Unity server must have permissions ...
We are using CUCM 8.5.1 and CUCILync 8.5.2Each end-user owns a shared line with: 1 User_Device_Profile logged on a physical Cisco Ip Phone 1 Remote_Destination_Profile + 1 Remote_Destination to mobile phone 1 CSframework CUCILync phoneWhen calling th...
Hi, My publisher has the error Buffer I/O error on device hda, logical block 11437 and Buffer I/O error on device hda, logical block 11435.Does anyone know what does this means and how to resolve it? Many thanks
hi,we have an CUCM 8.0.3 with some 6941 IP phones configured with SCCP. SRST Reference is set to a 2911 K9 Voice Gateway. Gateway IOS is 15.1(4)M and SRST version is 8.6In Case of SRST the 6941 phones doesnt register at the gateway. Here the output o...
Hi,We are using Cisco 3560 switches with Cisco 79xx and 69xx series phones connected to them.Whats the best practice for configuring an interface with a cisco phone connected to it? I'd like some consistency accross the board, are there any commands ...
Hi,For CUWL licensing if I am catering VG204 for 4 analogue conference phones , then the number of licenses I should be buying should be PUBLIC-IP-DEV-UWL X 4 or PUBLIC-IP-DEV-UWL X 8 .I am buying CUWL-STD.thanks
Hi,I have a questions.....Is possible configure a cluster of Unified Communication Manager 8.5 with server UCS C210 M2 and MCS7845I3?For example:UCS C210 M2 : PUB/SUB1 (Virtual servers)MCS7845I3 : SUB2Thanks for your help
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
4 | |
3 | |
2 | |
1 |
