Multiple carrier T1 Slips with 3845
I have a 3845 gateway with two T1 circuits coming from diverse carriers.  One is an ATM circuit the other a PRI. I'm experiecing slips on the PRI and I believe it to be a clocking issue where the clocks from each of the carriers is far enough off to cause them.  The clocking configuration is as follows.
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate aim 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/1/0
What happens is T1 controller 0/1/0 shows slips.  Now if I modify the network-clock-select statement such that controller 0/1/0 is the primary, it clears on that circuit but now the ATM circuit is throwing delineation errors.
I am at a loss.  Is there a way I can resolve this short of putting them on separate hardware or getting both circuits from the same carrier at the same CO?  Any help would be greatly appreciated.
Jaime
paolo bevilacqua
I don't think is anything you can do about. However slips on voice PRI, in practice, only affects faxes.
mcecilia
I have had this problem other times and I have asked second provider to take clock from me, and I have configured clock source internal in the second vendor pri.
Hope this helps
Sent from Cisco Technical Support Android App
