09-06-2012 01:57 PM - edited 03-16-2019 01:04 PM
I have a 3845 gateway with two T1 circuits coming from diverse carriers. One is an ATM circuit the other a PRI. I'm experiecing slips on the PRI and I believe it to be a clocking issue where the clocks from each of the carriers is far enough off to cause them. The clocking configuration is as follows.
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate aim 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/1/0
What happens is T1 controller 0/1/0 shows slips. Now if I modify the network-clock-select statement such that controller 0/1/0 is the primary, it clears on that circuit but now the ATM circuit is throwing delineation errors.
I am at a loss. Is there a way I can resolve this short of putting them on separate hardware or getting both circuits from the same carrier at the same CO? Any help would be greatly appreciated.
Jaime
09-06-2012 10:25 PM
I don't think is anything you can do about. However slips on voice PRI, in practice, only affects faxes.
09-06-2012 11:53 PM
I have had this problem other times and I have asked second provider to take clock from me, and I have configured clock source internal in the second vendor pri.
Hope this helps
Sent from Cisco Technical Support Android App
