multiple voice ports for a dial peer
Paul Austin
Level 4
Level 4
Hi Folks, I know there is a method in version 15.4 ? IOS where you can group T1/E1 voiceports together and reference them in a dial-peer so eliminating multiple dial-peers for the same pattern.
I just cant find the reference about it. Any ideas?
Paul
Its called trunk groups. Please see below. example
trunk group DMS
hunt-scheme sequential both up
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
trunk-group DMS timeslots 1-24 preference 1
controller T1 1/1
framing esf
linecode b8zs
trunk-group DMS timeslots 1-24 preference 2
controller T1 1/0/0
framing esf
linecode b8zs
trunk-group DMS timeslots 1-24 preference 3
dial-peer voice 2002 pots
trunkgroup DMS
destination-pattern 9[2-9]..[2-9]......
forward-digits 10
5 Replies 5
trunk group DMS
controller T1 1/0
framing esf
linecode b8zs
controller T1 1/1
framing esf
linecode b8zs
controller T1 1/0/0
framing esf
linecode b8zs
trunkgroup DMS
forward-digits 10
Hi Mohammed, Thanks for that. I did see that but I thought there was another way. I am sure that older way works just fine. I was looking at the voice class e164-pattern-map tag command and had it in my head that there was some other way - perhaps not and trunk group is what I was seeing.
Many Thanks
Hi Paul,
E164 pattern map is used to match multiple patterns for incoming or outgoing calls using single dialpeer. What you are looking for is different and the only way to achieve it is using trunk groups.
Hi, trunk groups are only applicable to outgoing dial-peers? Or do they also work for incoming? What if I have several voice-ports that have to have the same treatment for incoming calls, can I use trunk-groups too?
Thanks.
Yes you can.
Response Signature
