music on hold not work on external call
akram.root
Level 4
Level 4
I have a cucm v11.5 installed with gateway cisco ISR 4321,
the music on hold work fine in internal call, but not working on external call it head the beeps .
can you help me please the resolve this problem?
Best regards
Akram
9 Replies 9
Nashaatmusa
Can you screenshot your MRG and MGRL
Attach your gateway config
Dose the gateway has the MRGL assigned to it ?
thank you for your help
you can receive the config of the gateway isr in attachement.
in MRG and MGRL I have no config
best regards
R0g22
TON is usually a codec mismatch. Check your region settings for the MOH server (assuming you are using CUCM based resource for MOH) and the GW. In addition to that, is the GW H.323 ?
By default UCM only offers the g711 ulaw for Music on Hold
Go to System/Service Parameters and select "Cisco IP Voice Media Streaming App"
Check that all Codecs are selected
Graham
Thank you for your reply
I have all codec selected on cucm 11.5.
The problem is present only on external call.
Best regards
I only hear a beep
Best regards
I am not changing any codec . I kept the default config .
Best regards
This is not a fault or a problem. The system has been setup this way and it's because of conference calls. If someone is on a conference call and they put their phone on hold they flood the conference bridge with music so no one can hear.
If you set the network hold to a nonexistent audio stream then the system will  play the beeps instead of music.
If you want to restore music you will need to work out how it has been disabled.
Normally it is done by selecting a none existent MOH stream
Go to Service Parameters/Cisco CallManager
Check the Default Network Hold MOH Audio Source ID and Default User Hold MOH Audio Source ID are set to a valid MOH stream, normally 1
Graham
thank you for your reply and your informations.
I resolved the problem by adding the codec G.711 on gateway isr
Best regards
