Muting Callers to a Meet-Me Conference
BethanyTerry
Does anyone know how the conference controller can mute the callers that call in for a Meet-Me conference call? Apparently, we recently had a major Meet-Me call with assorted dept heads and state agencies calling in, and not everyone was kind enough to mute the phone on their end, so the controller has asked me if there's any way to mute callers so that the only person speaking is the controller himself. Any thoughts would be appreciated. (I have CUCM 10.5 and use 7965G phones). -Beth
2 Accepted Solutions
Jaime Valencia
You can't
java
if this helps, please rate
Wilson Samuel
Level 7
Level 7
Hi Bethany,
I checked the SRND as well as the Service Parameters in the CCM and I could not locate anywhere where it describes any way to define that.
More over, Cisco explicitly mentions Meet Me as an Rendezvous Meeting and is mostly basic configuration. For features like PIN, Mute etc I am afraid you may want to go the route of WebEx (in cloud or on premises) which is part of the CUWL Pro.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-licensing/product_solution_overview0900aecd806cc7a4.html
Please get in touch with your local Cisco AM and you will be better served.
5 Replies 5
Jaime Valencia
You can't
java
Thanks for your time Jaime. I suspected as much but had to ask the experts. -Beth
Hi.
Just to add a tip to what Jaime correctly mentioned, with cucm 11.x you can setup a conference number per user with access code feature.
Being based on meetme, here is reported the mute restriction.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_0_1/featureConfig/CUCM_BK_FE5123E0_00_cucm-feature-configuration-guide_1101/conference_now.html#CUCM_RF_C2EE34B5_00
Cheers
Carlo
Please rate all helpful posts "The more you help the more you learn"
Wilson Samuel
Level 7
Level 7
Hi Bethany,
Thanks for your time. I suspected as much but had to ask the experts. -Beth
