My Inbound and Outbound calls not working on CUCM > SIP trunk
Alexander Nejo
Hello Team,
I have CUCM (11.5) connected to a CUBE (2921) and SIP trunk to ITSP, but my inbound calls are not going through the sip trunk while the outbound calls are not working at all.
All the partition and CSS are configured correctly but am unable to loggs that shows my dialed numbers when i issue "debug ccsip mess" and "debug ccapi inout" is not going
Attached is my router configuration.
Kindly advise on how to resolve this.
13 Replies 13
If you do not get any output from these debugs when you make a call I would say that your call is not leaving CM. Check with DNA what it states for the call and if it does say that the call should be sent to the SBC check that all your CPE nodes are allowed in the trust list under voice service voip. Normally all destinations on the dial peer are all automatically allowed, but I always configure them specifically under that section either way just to be sure that they are all there.
Response Signature
Hi Roger, Thanks for your help.
I can see some debugs and showing "SIP/2.0 500 Server Internal Error"
SB-UC-VGW3#
login as: nlngadmin
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
OSB-UC-VGW3#debug ccsip mess
SIP Call messages tracing is enabled
OSB-UC-VGW3#term mon
OSB-UC-VGW3#Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 2201 7410 IN IP4 105.113.0.xx
s=SIP Call
c=IN IP4 105.113.0.xx
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
2009060: Mar 5 11:17:44.012: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:105.113.0.xx:5060 SIP/2.0
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKv2x1sxvcjgdm0cmqfejvxlqs1;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: qszesmq1e1dqdej1x112fv1j1qmezvsg@249.241.112.105
To: <sip:105.113.0.xx>
CSeq: 1 OPTIONS
Contact: <sip:105.112.241.xxx:36792;transport=udp;Hpt=8fb8_16>;expires=65535
Max-Forwards: 70
Content-Length: 0
2009061: Mar 5 11:17:44.016: //12860404/70B237F68D53/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE25520-25D4
Date: Tue, 05 Mar 2024 10:17:44 GMT
Server: Cisco-SIPGateway/IOS-15.7.3.M6
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 4591 826 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009062: Mar 5 11:17:46.024: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKqe1cmd1s2qdqf1xg0dcexqfqs;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: sgcdsqe00jlvc1eg0zclmlzgz0zq1zfe@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009063: Mar 5 11:17:46.028: //12860405/71E5D62F8D54/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE25D00-2308
Date: Tue, 05 Mar 2024 10:17:46 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6725 9109 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009064: Mar 5 11:17:48.044: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bK0xevmmvqqdfcddgzmsfmlgm0g;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: ej00l1cddgdcjsgqqde0dscdfzsseldf@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009065: Mar 5 11:17:48.044: //12860406/731974678D55/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE264E0-18DB
Date: Tue, 05 Mar 2024 10:17:48 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1473 7099 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009066: Mar 5 11:17:49.952: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.7.64.18:5060 SIP/2.0
Via: SIP/2.0/TCP 10.4.20.22:5060;branch=z9hG4bK2387cf19c261df
To: <sip:10.7.64.18>
Date: Tue, 05 Mar 2024 10:17:49 GMT
Call-ID: 9cdd0a00-5e61f14d-1ef161-1614040a@10.4.20.22
User-Agent: Cisco-CUCM11.5
CSeq: 101 OPTIONS
Contact: <sip:10.4.20.22:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
2009067: Mar 5 11:17:49.956: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.7.64.18>;tag=5FE26C54-23C1
CSeq: 101 OPTIONS
Content-Length: 363
v=0
o=CiscoSystemsSIP-GW-UserAgent 1117 7293 IN IP4 10.7.64.18
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
2009068: Mar 5 11:17:50.060: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKlx0mvj1f0dz0dvcdxcgejevs0;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: cxmledjmcdd22mfxm01fcqfggvzjlcmd@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009069: Mar 5 11:17:50.060: //12860408/744D12078D57/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE26CC0-379
Date: Tue, 05 Mar 2024 10:17:50 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 9819 8263 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009070: Mar 5 11:17:52.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKfgvz00xzc1qzxx20vvedg1qel;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: qgsqemfee00lqzces0xmdfvxl0m0zdfz@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009071: Mar 5 11:17:52.076: //12860409/758014188D58/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2749C-1AA2
Date: Tue, 05 Mar 2024 10:17:52 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 6995 772 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009072: Mar 5 11:17:53.932: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:08034044215@10.7.64.18:5060 SIP/2.0
Via: SIP/2.0/TCP 10.6.21.21:5060;branch=z9hG4bKf354e4496ebc5
From: "5209" <sip:5209@10.6.21.21>;tag=9224427~dc895605-e173-4522-8efa-78ecc79b9064-99854204
To: <sip:08034044215@10.7.64.18>
Date: Tue, 05 Mar 2024 10:17:53 GMT
Call-ID: 9f3f6400-5e61f151-662f9-1515060a@10.6.21.21
Supported: timer,resource-priority,replaces
Min-SE: 1800
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.6.21.21:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Session-ID: 4804683ff14b53c10798101aa9224404;remote=00000000000000000000000000000000
Cisco-Guid: 2671731712-0000065536-0000045919-0353699338
Session-Expires: 1800
P-Asserted-Identity: "5209" <sip:5209@10.6.21.21>
Remote-Party-ID: "5209" <sip:5209@10.6.21.21>;party=calling;screen=yes;privacy=off
Contact: <sip:5209@10.6.21.21:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 199
v=0
o=CiscoSystemsCCM-SIP 9224427 1 IN IP4 10.6.21.21
s=SIP Call
c=IN IP4 10.6.21.23
t=0 0
m=audio 27994 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
2009073: Mar 5 11:17:53.944: //12860411/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:08034044215@105.112.241.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP 105.113.0.xx:5060;branch=z9hG4bK6F111A1
Remote-Party-ID: "5209" <sip:05209@105.113.0.xx>;party=calling;screen=yes;privacy=off
From: "5209" <sip:05209@105.113.0.xx>;tag=5FE27BEC-CFD
To: <sip:08034044215@105.112.241.xxx>
Call-ID: 769DB719-DA1011EE-8D5EE318-D189C042@105.113.0.xx
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.7.3.M6
CSeq: 101 INVITE
Timestamp: 1709633873
Contact: <sip:05209@105.113.0.xx:5060>
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 7893 696 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=audio 25628 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
2009074: Mar 5 11:17:53.952: //12860410/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=4804683ff14b53c10798101aa9224404
Content-Length: 0
2009075: Mar 5 11:17:54.336: //12860411/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "5209"<sip:05209@105.113.0.xx>;tag=5FE27BEC-CFD
CSeq: 101 INVITE
Content-Length: 0
2009076: Mar 5 11:17:54.344: //12860411/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:08034044215@105.112.241.xxx>;tag=p0481913-CC-1025-OFC-217
CSeq: 101 INVITE
Reason: Q.850;cause=4;text="Send special information tone"
Content-Length: 0
2009077: Mar 5 11:17:54.344: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKqszjsx0cx00q1q2qg0vls2l2m;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: zgd2lz1je2101dxv0ml01es0dgg1xzvd@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009078: Mar 5 11:17:54.344: //12860411/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:08034044215@105.112.241.xxx:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: ;remote=
Content-Length: 0
2009079: Mar 5 11:17:54.344: //12860412/76DAC1AB8D5F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE27D7C-21CC
Date: Tue, 05 Mar 2024 10:17:54 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 2609 998 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009080: Mar 5 11:17:54.356: //12860413/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 105.113.0.xx:5060;branch=z9hG4bK6F22C8
From: "5209" <sip:05209@105.113.0.xx>;tag=5FE27D84-25C
Call-ID: 76DBF9FB-DA1011EE-8D61E318-D189C042@105.113.0.xx
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1709633874
Expires: 180
Max-Forwards: 68
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 5070 2349 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=audio 25644 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
2009081: Mar 5 11:17:54.792: //12860413/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "5209"<sip:05209@105.113.0.xx>;tag=5FE27D84-25C
To: <sip:08034044215@105.112.241.2xxx>
CSeq: 101 INVITE
Content-Length: 0
2009082: Mar 5 11:17:54.792: //12860413/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:08034044215@105.112.241.xxx>;tag=l3ykqkzz-CC-1011-OFC-217
CSeq: 101 INVITE
Content-Length: 0
2009083: Mar 5 11:17:54.800: //12860410/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:08034044215@10.7.64.18>;tag=5FE27F44-1F11
CSeq: 101 INVITE
Reason: Q.850;cause=41
Content-Length: 0
2009084: Mar 5 11:17:54.800: //12860413/9F3F64000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
2009085: Mar 5 11:17:55.476: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:08034044215@10.7.64.18:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
2009086: Mar 5 11:17:56.676: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKezsjve1gf02cj1zm1zqdzxvlg;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: j10zxglcq21qldfdfcx0ggvgxjfvl10q@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009087: Mar 5 11:17:56.712: //12860414/783E96C68D62/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE28698-220A
Date: Tue, 05 Mar 2024 10:17:56 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 6557 658 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009088: Mar 5 11:17:58.724: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKl0l22flxqfdjedxql01dez1gx;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: d0cxe1x0dldzv10vv1d1jfqjmdledzzj@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009089: Mar 5 11:17:58.728: //12860415/797716D78D63/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE28E98-EDB
Date: Tue, 05 Mar 2024 10:17:58 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 149 6913 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009090: Mar 5 11:18:00.740: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKsfzf1sf2essz2xgz0djv2csdz;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: zv2dmges0ffdfc22ld10mglsjmlzj0gv@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009091: Mar 5 11:18:00.740: //12860416/7AAAB4778D64/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE29678-2332
Date: Tue, 05 Mar 2024 10:18:00 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 951 2787 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009092: Mar 5 11:18:02.792: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKdlqevgddscmzvlfx1ve1jqlv0;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: mdlem2cxmjcgdjjcmecgmzv1v0edzfsm@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009093: Mar 5 11:18:02.796: //12860417/7BE3D0AF8D65/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE29E7C-C30
Date: Tue, 05 Mar 2024 10:18:02 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 5992 2650 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009094: Mar 5 11:18:04.808: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bK2q1xcdg2vels1cx0mldflgsjc;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: e1m1xsjgvqxvef1s2zsjqxvx2vjfec1x@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009095: Mar 5 11:18:04.812: //12860418/7D176EE88D66/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2A65C-1CF8
Date: Tue, 05 Mar 2024 10:18:04 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 8820 412 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009096: Mar 5 11:18:07.252: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.2.20.21:5060;branch=z9hG4bKa06d7456f2a15d
Date: Tue, 05 Mar 2024 10:18:06 GMT
Call-ID: a6ff0880-5e61f15e-369f7c-1514020a@10.2.20.21
CSeq: 101 OPTIONS
Contact: <sip:10.2.20.21:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
2009097: Mar 5 11:18:07.256: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bK11mdevjj0vvsx0g0ejesvdf2l;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: zmsedzqjsqx1zgvejxzcse1cf21vgz2l@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009098: Mar 5 11:18:07.260: //12860420/7E8CF8F28D68/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2AFEC-65B
Date: Tue, 05 Mar 2024 10:18:07 GMT
CSeq: 1 OPTIONS
Content-Length: 369
v=0
o=CiscoSystemsSIP-GW-UserAgent 273 955 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009099: Mar 5 11:18:07.260: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.7.64.18>;tag=5FE2AFE8-1BC8
CSeq: 101 OPTIONS
Content-Length: 363
v=0
o=CiscoSystemsSIP-GW-UserAgent 1838 2451 IN IP4 10.7.64.18
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
2009100: Mar 5 11:18:09.272: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bK0f1zvfjcemvdq0ef1mzjcxe10;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: lgcj1lqzqvg22lggme122sxgdqdmc2zq@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009101: Mar 5 11:18:09.276: //12860421/7FC0972A8D69/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2B7CC-1087
Date: Tue, 05 Mar 2024 10:18:09 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6271 8485 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009102: Mar 5 11:18:11.288: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKc2q1cddsdj02melfev0fffdxj;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: szcxg1sv2zff1dj02cm2ml0e112jzvxe@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009103: Mar 5 11:18:11.288: //12860422/80F435638D6A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2BFAC-868
Date: Tue, 05 Mar 2024 10:18:11 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 5787 4718 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009104: Mar 5 11:18:13.296: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKefgss21vd0vzjmvf2ms1jjexv;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: cjdjq1dmmjdg0vefgjcx22ccc01d1v2f@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009105: Mar 5 11:18:13.300: //12860423/82269AB38D6B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2C784-D4F
Date: Tue, 05 Mar 2024 10:18:13 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1460 5129 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009106: Mar 5 11:18:15.312: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bK2fxvcx1qz2qdm2xezfjjdlg0g;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: 0jzz1fe0vcfcqscezl0v2qgxs1jqcfeq@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009107: Mar 5 11:18:15.312: //12860424/835A38EB8D6C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2CF64-200C
Date: Tue, 05 Mar 2024 10:18:15 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4884 5575 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009108: Mar 5 11:18:17.196: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.6.21.22:5060;branch=z9hG4bK9d92e519871a2
Date: Tue, 05 Mar 2024 10:18:16 GMT
Call-ID: acf4e980-5e61f168-77165-1615060a@10.6.21.22
CSeq: 101 OPTIONS
Contact: <sip:10.6.21.22:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
2009109: Mar 5 11:18:17.200: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.7.64.18>;tag=5FE2D6C0-1738
Date: Tue, 05 Mar 2024 10:18:17 GMT
CSeq: 101 OPTIONS
Content-Length: 363
v=0
o=CiscoSystemsSIP-GW-UserAgent 2151 2300 IN IP4 10.7.64.18
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
2009110: Mar 5 11:18:17.324: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKzlelq0mdxjcfz2zjs2jdcv0sj;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: 2sqqcq1qg2fxvjlm2gjgm20ejmdqzszg@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009111: Mar 5 11:18:17.328: //12860426/848D3A638D6E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2D740-2F2
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 169 6941 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009112: Mar 5 11:18:19.336: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKddzx1dscxjd2vmej0xeegfzg1;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: z1mlcz1mjl0sc1jqdqqm2lgjvefgzs2v@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009113: Mar 5 11:18:19.340: //12860427/85C03C738D6F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2DF20-181F
Date: Tue, 05 Mar 2024 10:18:19 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6951 2512 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009114: Mar 5 11:18:21.352: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bKzvjzlvges1j0x1glllde0j0zq;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: cfvjg0l2vqdxfvsc1geevxj0c00s0gz0@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009115: Mar 5 11:18:21.352: //12860428/86F3DA138D70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2E6FC-24A9
Date: Tue, 05 Mar 2024 10:18:21 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 3749 6146 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
2009116: Mar 5 11:18:23.368: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bK00velzs21s1xdxl0qj2ldfgeg;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: ljvzdezf0ddd0mzssfql2lfg10eg00z2@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009117: Mar 5 11:18:23.372: //12860429/8827784C8D71/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2EEE0-B47
Date: Tue, 05 Mar 2024 10:18:23 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 3523 837 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
u a
2009118: Mar 5 11:18:25.384: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 105.112.241.xxx:5060;branch=z9hG4bK11fjqfx10ldslzsseeesxc1gx;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: f1sjgdzxcsevfsj1geqslexzv1e2mcd2@249.241.112.105
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
2009119: Mar 5 11:18:25.388: //12860430/895B16848D72/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105.113.0.xx>;tag=5FE2F6BC-FA1
Date: Tue, 05 Mar 2024 10:18:25 GMT
CSeq: 1 OPTIONS
ll
All possible debugging has been turned off
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 3591 6435 IN IP4 105.113.0.xx
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
SB-UC-VGW3#
login as: nlngadmin
| Password:
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 OPTIONS
Content-Length: 363
v=0
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 199
v=0
s=SIP Call
c=IN IP4 10.6.21.23
t=0 0
a=fmtp:101 0-15
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
CSeq: 101 INVITE
Content-Length: 0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 247
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
CSeq: 101 INVITE
Content-Length: 0
Sent:
CSeq: 101 INVITE
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 369
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sent:
SIP/2.0 200 OK
CSeq: 101 OPTIONS
Content-Length: 363
v=0
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 OPTIONS
Content-Length: 363
v=0
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 370
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
u a
Received:
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
ll
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
It is the service provider that sends the 500 Server Internal Error to you. You'd need to contact them and ask them why they do that.
If I would make a guess it is because you're sending them calling number information in a format that they do not like as you send it in what seem to be the four digit internal extension format with a zero added in-front of it.
Received:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 199
v=0
s=SIP Call
c=IN IP4 10.6.21.23
t=0 0
a=fmtp:101 0-15
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
CSeq: 101 INVITE
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 247
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
CSeq: 101 INVITE
Content-Length: 0
Sent:
CSeq: 101 INVITE
Content-Length: 0
Response Signature
Alexander Nejo
Thanks once again Roger, Please how do i change the 05209 format to 0911xxx5209 ? do i change it from the router with voice translation-rule or from the cucm?
It’s really your preference that dictate how you go about this. Me personally I’d prefer to use voice translation rules as I prefer to deal with calling and called number transformations as close to the egress/ingress point to/from the service provider as possible.
Response Signature
I see you already have translation rules on CUBE, both inbound and outbound. Is it not matching?
If your network already use gateway translations, better go with it.
if your network already use call manager translations, go with it.
As per last update, it depends on what's already is in practice. Also, check dial-peers on voice gateway.
Hello Team, I have tried configure the translation from the CUCM end and the error is still showing.
Below is the debug, please what can i do next or can someone show a sample config on the necessary translation?
SB-UC-VGW3#d
2013034: Mar 6 10:57:50.314: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.2.20.20:5060;branch=z9hG4bK6c232a0c32e0
Date: Wed, 06 Mar 2024 09:57:50 GMT
Call-ID: fc9de880-5e813e1e-6c24-1414020a@10.2.20.20
CSeq: 101 OPTIONS
Contact: <sip:10.2.20.20:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
2013035: Mar 6 10:57:50.318: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.7.64.18>;tag=64F67A08-1323
CSeq: 101 OPTIONS
ebSupported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 360
v=0
o=CiscoSystemsSIP-GW-UserAgent 5 5403 IN IP4 10.7.64.18
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
2013036: Mar 6 10:57:51.338: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.6.21.21:5060;branch=z9hG4bKf9c715d23fe1e
Date: Wed, 06 Mar 2024 09:57:51 GMT
Call-ID: fd367f00-5e813e1f-69099-1515060a@10.6.21.21
CSeq: 101 OPTIONS
Contact: <sip:10.6.21.21:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
2013037: Mar 6 10:57:51.342: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.7.64.18>;tag=64F67E0C-1C21
CSeq: 101 OPTIONS
Content-Length: 363
v=0
o=CiscoSystemsSIP-GW-UserAgent 7234 2746 IN IP4 10.7.64.18
s=SIP Call
c=IN IP4 10.7.64.18
t=0 0
c=IN IP4 10.7.64.18
m=image 0 udptl t38
c=IN IP4 10.7.64.18
a=T38FaxVersion:0
2013038: Mar 6 10:57:51.798: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:105.113.0.46:5060 SIP/2.0
Via: SIP/2.0/UDP 105.112.241.249:5060;branch=z9hG4bKjvcflzxsqmffed2zffxmdf2lv;Role=3;Hpt=8fb8_16;pth=0;X-HwDim=4
Call-ID: zszcf2sv0ldmfv2qjqff1mgzs22jzjqq@249.241.112.105
To: <sip:105.113.0.46>
CSeq: 1 OPTIONS
Contact: <sip:105.112.241.249:36792;transport=udp;Hpt=8fb8_16>;expires=65535
Max-Forwards: 70
Content-Length: 0
There is no call in the debug output, only SIP option ping. Please check that the call reaches your router and when you’re sure collect the output from these debugs running all at once, debug ccsip message, debug voip ccapi inout and debug voip translation. Please attach the output in a text file instead of posting it directly into your reply as it makes the post really long and harder to read.
Response Signature
^^^ THIS
@Steven L This what?
Response Signature
was agreeing with you. i was about to post the same comment.
Alexander Nejo
Apologies wanted to do that but had an error.
Kindly share the translation rule template (if u have)
Without seeing your configuration this will just be a guess game, but something similar to this could work.
voice translation-rule 30
 rule 1 /\(.*\)/ /\1/ !If you'd where to need to modify calling number this would be the rule set you'll do that in
voice translation-rule 40
 rule 1 /\(.*\)/ /0911xxx\1/ !Change xxx to what you'd need
voice translation-profile PSTN-OUT
 translate calling 30
 translate called 40
dial-peer voice 110 voip
 description Outbound calls to PSTN
 translation-profile outgoing PSTN-OUT
There are really good documentation on cisco.com, advice you to read up on this. To get you started have a look at these.
In Depth Explanation of Cisco IOS and IOS-XE Call Routing - Cisco
Determine Voice Translation Rules
Understand Inbound/Outbound Dial Peers that Match on IOS Platforms
Response Signature
