IP Telephony and Phones
Labels
This is the config from an old 2921 that we are currently using as a SIP to PRI bridge for our FaxCore installation.service tcp-keepalives-inservice tcp-keepalives-outservice timestamps debug datetime msec localtime show-timezone yearservice timestam...
Please excuse my newbie approach to this, it's the first time I've posted here. Jabber will open as if it is going to launch, halts, then opens a window asking you enter information to download the log files. I have a attached photos.
sbdavies by Level 1
  • 1064 Views
  • 3 replies
Good day. I have some troubles with SAML SSO. I installed certificates, then I configured ADFS and CUCM to use SSO. And firstly all worked fine. I could login to CUCM and to Self-care portal with windows credentials. But there was a notifications at ...
My Cisco headset 562 stops working 6-10 minutes into the call. It makes a static sound and then it stops working. Is this possibly because the headset battery no longer retaining charge and if so, how can we replace the headset battery?
sonami by Level 1
  • 393 Views
  • 3 replies
