My IP phones doesn´t update the firmware, after we upgrade from CallManager 3.3 to 7.1.5
jonathangomez
Level 4
Level 4
The CallManager 7.1.5 is a new installation.
I don´t know why this happens.
The phones still remain with the old firmware images.
Rob Huffman
Hi Jonathan,
I'm guessing that your IP Phones may require an incremental upgrade
approach before being able to get to the Firmware that is default with
CUCM 7.1(5). If you can provide the Model (s) in question and their current
Firmware Load (s) I'm sure we can help
Cheers!
Rob
Hi Rob.
Thanks for your info.
The phones ares 7940/60, 7970 and 7912.
ACTUAL FIRMWARES
P00307010200  ---> 7960
App Load ID  Jar70.2-8-0-98.sbn
Boot Load ID  7970_64060118.bin ---->  7970
App Load ID CP7912080003SCCP070409A
Boot Load ID LD0100BOOT021112A ---->  7912
Rob Huffman
Hi Jonathan,
Yes, like we thought...you are running into the issues listed below due to the
version(s) of your existing Firmware;
Check out what 7.1(5) is trying to load
Table 20 Default Loads for Cisco Unified Communications Manager Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43813
For the 7940's
Note You cannot upgrade to firmware release 8.1(2) directly from firmware release 8.0(10) or an earlier release. You have to upgrade to firmware release 8.1(1) first, then upgrade from release 8.1(1) to release 8.1(2).
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/firmware/8_1_2/english/release/notes/796040_812.html
For the 7970's
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 8.5(3) or greater, you must first upgrade your firmware to version 8.5(2). Once you have upgraded to version 8.5(2), you can upgrade your IP Phone to version 8.5(3) or later.
Note This section applies to the Cisco Unified IP Phone 7971G-GE, 7970G, 7961G-GE, 7961G, 7941G-GE, 7941G, 7911G, and 7906G.
The following upgrade issues apply:
•If you are currently running firmware earlier than 6.0(2) on a Cisco Unified IP Phone and want to upgrade to 8.x(x), you must first install an intervening 7.0(x) load to prevent upgrade failure. Cisco recommends using the most recent 7.0(3) load as the intervening load to avoid lengthy upgrade times.
•If you are currently running firmware 6.0(2) to 7.0(2) on a Cisco Unified IP Phone and want to upgrade to 8.x(x), you can do so directly. However, expect the upgrade to take twice as long as usual.
•Device packs are required to enable IP Phones in the Cisco Unified Communications Manager database. For Cisco Unified CallManager 4.2 and earlier, these device packs are required. For Cisco Unified CallManager 4.3 and Cisco Unified Communications Manager 6.0 and later, you must run the device pack and reboot the Cisco Unified Communications Manager server.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_3/english/release/notes/7900_853.html
Cheers!
Rob
thanks rob for all.
I'm going to  do the procedure, I hope that everything works...
Best regards.
Jonathan.
