Native Presence Issue
Operepichay
Cucm version is 11.0.1.22900-14
BLF For Call Lists is enabled in Enterprise Parameters Configuration. Phones are rebooted.
Native presence works in CIPC but not in 7940/7941 IP Phones. All phones are in standard presence group
What can be wrong?
2 Accepted Solutions
Jaime Valencia
The 7940 does not support that feature
CSCsq47442    BLF on call list not supported on 7940/7960 phones
java
if this helps, please rate
Robert Shaw
Level 3
Level 3
Also, apart from Jaime's response, please see below compatibility matrix.  The 7940/41 phones have not been supported since at least version 10.5.  Although they do work, you will find other minor issues.  It's time to upgrade them I'm afraid.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
Rob
Jaime Valencia
java
Robert Shaw
Level 3
Level 3
Rob
