Need help deciphering router config for voip.
daniel espinal
I'm a total newbie. I've inherited this complex cisco voip system and I have not the slightest idea what if anything this router is providing to the over all voip system. I was hoping someone could take a look at this config and tell me what consciousness removing this router would have on the voip system. There is a call manager server providing the voip functionality. I want to remove this router and replace it with a non cisco router but I'm afraid the voip system will stop working.
! Last configuration change at 15:57:07 EST Fri Dec 7 2012 by administrator
version 12.4
parser cache
no service log backtrace
no service config
no service exec-callback
service nagle
service slave-log
no service slave-coredump
no service pad to-xot
no service pad from-xot
no service pad cmns
service pad
no service telnet-zeroidle
no service tcp-keepalives-in
no service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
no service exec-wait
no service linenumber
no service internal
no service scripting
no service compress-config
service prompt config
no service old-slip-prompts
no service pt-vty-logging
no service disable-ip-fast-frag
no service sequence-numbers
hostname NYC-CER-Router
boot-start-marker
boot-end-marker
logging exception 4096
no logging count
no logging message-counter log
no logging message-counter debug
logging message-counter syslog
no logging snmp-authfail
no logging userinfo
logging buginf
logging queue-limit 100
logging queue-limit esm 0
logging queue-limit trap 100
logging buffered 560000
no logging persistent
logging rate-limit console 10 except errors
logging console guaranteed
logging console debugging
logging monitor debugging
logging on
enable secret 5 ******
aaa new-model
aaa authentication login VPNauthen local
aaa authorization network groupauthor local
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
errdisable detect cause all
errdisable recovery interval 300
network-clock-switch 10 10
dot11 syslog
dot11 activity-timeout unknown default 60
dot11 activity-timeout client default 60
dot11 activity-timeout repeater default 60
dot11 activity-timeout workgroup-bridge default 60
dot11 activity-timeout bridge default 60
dot11 aaa csid default
prompt config hostname-length 20
no ip source-route
ip icmp redirect subnet
ip spd queue threshold minimum 73 maximum 74
ip cef
no ip domain lookup
ip multicast-routing
ip inspect log drop-pkt
ip inspect max-incomplete low 400
ip inspect max-incomplete high 500
ip inspect one-minute low 300
ip inspect one-minute high 400
ip inspect udp idle-time 300
ip inspect dns-timeout 10
ip inspect tcp idle-time 300
ip inspect tcp synwait-time 10
ip inspect tcp max-incomplete host 50 block-time 0
ip inspect name inspect_rule ftp
ip inspect name inspect_rule dns
ip inspect name inspect_rule http
ip inspect name inspect_rule https
ip inspect name inspect_rule icmp
ip inspect name inspect_rule imap
ip inspect name inspect_rule smtp
ip inspect name inspect_rule ntp
ip inspect name inspect_rule tcp
ip inspect name inspect_rule udp
ip inspect name inspect_rule pop3
ip inspect name inspect_rule ssh
ip inspect name inspect_rule echo
ip inspect name inspect_rule isakmp
ip igmp snooping vlan 1
ip igmp snooping vlan 1 mrouter learn pim-dvmrp
ip igmp snooping
no ipv6 cef
ipv6 dhcp ping packets 0
ntp master
ntp server 192.5.41.40
ntp server 192.5.41.41
ntp server 192.5.41.42
stcapp timer roh 45
stcapp security mode none
stcapp call-control mode standard
cwmp agent
no enable download
no enable
request outstanding 5
parameter change notify interval 60
session retry limit 11
management server username 00000C-CISCO2811V06-FTX1330A0K5
no management server password
no management server url
no provision code
no connection request username
no connection request password
no wan ipaddress
mls qos map cos-dscp 0 8 16 26 32 46 48 56
trunk group POTS
max-calls any 65535 direction in
max-calls any 65535 direction out
max-calls voice 65535 direction in
max-calls voice 65535 direction out
max-calls data 65535 direction in
max-calls data 65535 direction out
max-retry 0
description
hunt-scheme sequential
voice call trap deviation 49
voice call trap deviation 49 vad
voice call send-alert
no voice call disc-pi-off
no voice call convert-discpi-to-prog
no voice call debug full-guid
voice call carrier capacity timer interval 25
voice call trunkgroup capacity timer interval 25
voice call prefix capacity timer interval 25
voice call carrier trigger percent-change 30
voice call trunkgroup trigger percent-change 30
voice call prefix trigger percent-change 30
voice call carrier trigger lwm 10
voice call trunkgroup trigger lwm 10
voice call prefix trigger lwm 10
voice call carrier trigger hwm 80
voice call trunkgroup trigger hwm 80
voice call prefix trigger hwm 80
voice call carrier capacity mir 10
voice call trunkgroup capacity mir 10
voice call prefix capacity mir 10
voice call carrier capacity stw 10
voice call trunkgroup capacity stw 10
voice call prefix capacity stw 10
no voice call carrier capacity reporting maxima
no voice call trunkgroup capacity reporting maxima
no voice call prefix capacity reporting maxima
no voice call carrier capacity reporting inflection
no voice call trunkgroup capacity reporting inflection
no voice call prefix capacity reporting inflection
voice call carrier csr reporting interval 25
voice call trunkgroup csr reporting interval 25
voice call prefix csr reporting interval 25
voice call carrier csr recording interval 60
voice call trunkgroup csr recording interval 60
voice call prefix csr recording interval 60
voice call carrier csr growth interval 10
voice call trunkgroup csr growth interval 10
voice call prefix csr growth interval 10
voice call carrier csr data-points 30
voice call trunkgroup csr data-points 30
voice call prefix csr data-points 30
voice rtp send-recv
no voice disc-pi-incoming-on
voice dsp crash-dump file-limit 0
voice service pots
fax rate voice
voice service voip
notify redirect ip2ip
no callmonitor
no rtp-ssrc multiplex
no dtmf-interworking rtp-nte
cpa
cpa timing silent 375
cpa timing live-person 2500
cpa timing timeout 3000
cpa timing noise-period 100
cpa timing valid-speech 112
cpa timing term-tone 15000
cpa threshold noise-level max -50dBm0
cpa threshold noise-level min -60dBm0
cpa threshold active-signal 15db
media flow-through
allow-connections h323 to sip
allow-connections sip to h323
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service h225-notify cid-update
no redirect ip2ip
text relay modulation baudot45.45 autobaud-on
fax protocol pass-through g711ulaw
  no cause-code legacy
h323
  h450 h450-2 timeout T1 2000
  h450 h450-2 timeout T2 5000
  h450 h450-2 timeout T3 5000
  h450 h450-2 timeout T4 5000
  h450 h450-3 timeout T1 5000
  no emptycapability
  no billing b-channel
  telephony-service ccm-compatible
  ccm-compatible
  ip circuit max-calls 1000
  no ip circuit default only
  ip circuit default name cisco-default-h323-circuit
  ras brq
  no ras rrq dynamic prefixes
  ras rrq ttl 60  margin 15
  ras timeout grq 5
  ras timeout rrq 5
  ras timeout arq 3
  ras timeout drq 3
  ras timeout brq 3
  ras timeout rai 3
  ras retry grq 2
  ras retry rrq 2
  ras retry arq 2
  ras retry drq 9
  ras retry brq 2
  ras retry rai 9
  h225 timeout tcp call-idle value 10
  h225 timeout t302 10
  h225 timeout setup 15
  h225 timeout keepalive
  h225 timeout call-proceeding 60
  no h225 signal overlap
  no h225 setup t38
  no h225 progress-indicator local-ringback
  no h225 start-h245 on-connect
  h225 listen-port 1720
  no h225 display-ie ccm-compatible
  h225 h245-address on-connect
  no h225 h245-address setup
  h225 h245-address facility
  h225 h245-address progress
  h225 h245-address sync
  h225 alt-ep hunt all
  no h225 alt-ep cdr
  no h225 id-passthru
  no h225 connect-passthru
  call start fast
  call preserve limit-media-detection
  session transport tcp calls-per-connection 5
  no bearercap-ie signaling-only
  no h245 tunnel disable
  no h245 caps mode restricted
  no h245 caps suppress nte
  h245 timeout olc 4
  h245 timeout tcs 15
  no h245 passthru tcsnonstd-passthru
  no h245 passthru all
  h245 sanitization
  no settlement-token cisco
modem passthrough nse payload-type 100 codec g711ulaw  sample-duration 0  maximum-sessions 16 gw-controlled
modem relay latency 200
modem relay gateway-xid dictionary 1024 string-length 32 compress backward
modem relay sse redundancy interval 20
modem relay sse redundancy packet 3
modem relay sse t1 1000
modem relay sse retries 3
modem relay sprt retries 12
modem relay sprt v14 receive playback hold-time 50
modem relay sprt v14 transmit hold-time 20
modem relay sprt v14 transmit maximum hold-count 16
sip
  session transport udp
  rel1xx supported "100rel"
  rtp send-recv
  url sip
  min-se 1800
  subscription maximum accept 2147483647
  subscription maximum originate 2147483647
  no registrar server
  no privacy
  redirect contact order longest-match
  update-callerid
  no authenticate redirecting-number
  bearer-capability clear-channel speech
  anat
  listen-port non-secure  5060
  listen-port secure  5061
  no srtp negotiate
  no early-offer forced
  no history-info
  no midcall-signaling passthru
  no bandwidth audio as-modifier
  no bandwidth video as-modifier
  no g729 annexb-all
voice class uri sip preference host user-id
voice class codec 1
codec preference 1 g711ulaw bytes 160
codec preference 2 g729r8 bytes 20
voice class h323 1
  h225 timeout tcp establish 6
  h225 timeout connect 180
  h225 timeout t304 10
  h225 h245-address system
  call start system
  call preserve
  call sync-rsvp slow-start
  no codec bytes preferred local
  h245 caps mode system
  ccm-compatible system
no voice mlpp
voice vad-time 250
voice statistics max-storage-duration
voice statistics display-format separator
voice statistics field-params mcd 2
voice statistics field-params lost-packet 1000
voice statistics field-params packet-latency 250
voice statistics field-params packet-jitter 250
voice statistics push ftp max-file-size 4294967295
voice-card 0
echo-canceller fast-noise-match
dspfarm
dsp services dspfarm
local-bypass
watchdog
fax receive max-speed 14400
fax send max-speed 14400
fax send coverpage enable
fax send coverpage show-detail
fax send coverpage email-controllable
fax interface-type none
mta receive maximum-recipients 0
mta receive generate mdn
mta receive generate permanent-error
mta receive disable-dsn
no mmoip aaa send-accounting enable
no mmoip aaa send-authentication enable
no mmoip aaa receive-accounting enable
no mmoip aaa receive-authentication enable
http client cache memory pool 10000
http client cache memory file 50
no http client cache query
http client cookie
http client connection persistent
http client connection timeout 5
http client connection idle timeout 2
http client response timeout 10
ivr prompt cutoff-threshold 500
ivr prompt streamed none
ivr record memory system 10240
ivr record memory session 250
ivr record jitter tftp: 32000
ivr record jitter http: 32000
ivr record cpu flash 15
mrcp client timeout connect 3
mrcp client timeout message 3
mrcp client session history duration 10
mrcp client session history records 50
mrcp client session nooffailures 5
vxml tree memory 1024
vxml audioerror
vxml version 2.0
vxml allow-star-digit
vxml fetchaudio-nonblocking
vxml cng ignore
crypto pki trustpoint TP-self-signed-3640433359
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3640433359
revocation-check none
rsakeypair TP-self-signed-3640433359
crypto pki certificate chain TP-self-signed-3640433359
certificate self-signed 01
      quit
no snap notification exclude service acl
no snap notification exclude service eem
no snap notification exclude service snapt
port-channel load-balance src-dst-ip
file prompt alert
emm clear 1b5b324a1b5b303b30480d
vtp file flash:vlan.dat
vtp mode server
vtp version 1
username administrator privilege 15 secret 5 *********/
archive
log config
  no record rc
  no logging enable
  logging size 100
  no notify syslog contenttype plaintext
  no notify syslog contenttype xml
  hidekeys
no path
no rollback filter adaptive
rollback retry timeout 0
scripting tcl low-memory 21108014
scripting tcl trustpoint untrusted terminate
no scripting tcl secure-mode
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key N0w@y1n address 96.56.130.*** no-xauth
no crypto isakmp diagnose error
crypto ipsec transform-set RTRAmagansett esp-aes esp-md5-hmac
crypto map amagansett 20 ipsec-isakmp
set peer 96.56.130.***
set transform-set RTRAmagansett
match address RTRAmagansett
ip tftp source-interface FastEthernet0/0
ip ssh time-out 120
ip ssh authentication-retries 3
ip ssh source-interface FastEthernet0/0
ip ssh break-string ~break
ip ssh version 2
ip ssh dh min size 1024
interface Loopback0
no ip address
ip redirects
ip proxy-arp
snmp trap link-status
no h323-gateway voip interface
interface Tunnel0
description GRE over IPsec tunnel to Amagansett
ip address 10.0.254.1 255.255.255.0
ip redirects
ip proxy-arp
tunnel source FastEthernet0/1
tunnel destination 96.56.130.***
description Private Interface
ip address 10.0.1.1 255.255.255.0
ip redirects
ip proxy-arp
ip nat inside
ip virtual-reassembly
duplex full
speed 100
h323-gateway voip bind srcaddr 10.0.1.1
interface FastEthernet0/1
description Public Interface
ip address dhcp
ip access-group internet_in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect inspect_rule out
duplex auto
speed auto
no cdp enable
interface Integrated-Service-Engine1/0
ip address 10.0.21.1 255.255.255.0
ip redirects
ip proxy-arp
ip nat inside
service-module ip address 10.0.21.2 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.0.21.1
no keepalive
ip local pool VPNpool 10.0.11.1 10.0.11.60
ip classless
ip forward-protocol nd
ip route 10.0.0.0 255.255.0.0 10.0.1.2
ip route 10.1.0.0 255.255.0.0 10.0.254.2
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
ip http port 80
ip http authentication local
no ip http secure-server
ip http secure-port 443
ip http secure-active-session-modules all
ip http max-connections 5
ip http timeout-policy idle 180 life 180 requests 1
ip http active-session-modules all
ip http digest algorithm md5
ip http client cache memory pool 100
ip http client cache memory file 2
ip http client cache ager interval 5
ip http client connection timeout 10
ip http client connection retry 1
ip http client connection idle timeout 30
ip http client response timeout 30
ip http path flash:
ip rtcp report interval 5000
ip rtcp sub-rtcp message-type 209
ip nat pool Inet-pool 129.44.48.*** 129.44.48.*** netmask 255.255.255.0
ip nat inside source list 110 interface FastEthernet0/1 overload
ip access-list extended RTRAmagansett
permit gre host 129.44.48.*** host 96.56.130.***
ip access-list extended internet_in
deny   tcp any host 68.161.229.147 eq 5060
deny   tcp any host 68.161.229.147 eq 5061
deny   udp any host 68.161.229.147 eq 5060
deny   udp any host 68.161.229.147 eq 5061
permit udp any any eq bootps
permit udp any any eq bootpc
permit udp any any eq domain log
permit udp any any range 10000 20000
permit ip host 208.67.***.*** any
permit ip host 192.5.41.41 any
permit ip host 192.5.41.40 any
permit ip host 192.5.41.42 any
permit gre any any
permit esp any any
permit ahp any any
permit icmp any any
permit udp any any eq isakmp
permit udp any eq isakmp any
permit udp any any eq non500-isakmp
permit udp any eq 10000 any
permit udp any any eq 10000
permit udp any eq non500-isakmp any
permit tcp any any eq 22
deny   ip any any log-input
no ip sla logging traps
logging history size 1
logging history warnings
logging trap informational
logging delimiter tcp
logging facility local7
no logging source-interface
access-list 102 remark Split-Tunnel Access-list
access-list 102 permit ip 10.0.1.0 0.0.0.255 10.0.11.0 0.0.0.255
access-list 102 permit ip 10.0.10.0 0.0.0.255 10.0.11.0 0.0.0.255
access-list 102 permit ip 10.0.30.0 0.0.0.255 10.0.11.0 0.0.0.255
access-list 102 permit ip 10.0.20.0 0.0.0.255 10.0.11.0 0.0.0.255
access-list 110 remark NAT translations
access-list 110 deny   ip 10.0.0.0 0.255.255.255 10.0.11.0 0.0.0.255
access-list 110 deny   ip 10.0.0.0 0.0.255.255 10.1.0.0 0.0.255.255
access-list 110 permit ip 10.0.1.0 0.0.0.255 any
access-list 110 permit ip 10.0.10.0 0.0.0.255 any
access-list 110 permit ip 10.0.20.0 0.0.0.255 any
access-list 110 permit ip 10.0.21.0 0.0.0.255 any
access-list 110 permit ip 10.0.30.0 0.0.0.255 any
access-list 110 permit ip 10.0.40.0 0.0.0.255 any
mac-address-table aging-time 300
cdp run
snmp-server inform retries 3 timeout 15 pending 25
snmp mib event sample minimum 60
snmp mib event sample instance maximum 0
snmp mib expression delta minimum 1
snmp mib expression delta wildcard maximum 0
snmp mib nhrp
snmp mib notification-log globalsize 500
snmp mib notification-log globalageout 15
snmp mib community-map  ILMI engineid 80000009030000260BB75C30
control-plane
call fallback probe-timeout 30
call fallback wait-timeout 300
call fallback threshold icpif 5
call fallback jitter-probe precedence 2
call fallback jitter-probe num-packets 10
call fallback cache-size 128
call fallback cache-timeout 600
call fallback reject-cause-code 49
call fallback instantaneous-value-weight 66
call fallback expect-factor 10
call fallback icmp-ping codec g729r8 size 32 count 5 interval 10 loss 20 timeout 500
call treatment on
call rsvp-sync resv-timer 10
call rsvp-sync
call threshold poll-interval cpu-avg 60
call threshold poll-interval memory 5
call rscmon update-timer 2000
voice-port 0/0/0
trunk-group POTS 3
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
battery-reversal detection-delay 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
output attenuation 3
echo-cancel enable
echo-cancel coverage 64
echo-cancel erl worst-case 6
echo-cancel mode 0
non-linear threshold -21
non-linear comfort-noise attenuation 6db
vad
compand-type u-law
playout-delay maximum 1000
playout-delay nominal 60
playout-delay fax 300
playout-delay minimum default
playout-delay mode adaptive
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timeouts interdigit 10
timeouts call-disconnect 60
timeouts ringing 180
timeouts wait-release 30
timing hookflash-out 50
timing digit 100
timing inter-digit 100
timing pulse 10
timing percentbreak 60
timing guard-out 2000
timing min-ring 125
timing sup-disconnect 350
timing opx-ringwait 6000
timing pulse-inter-digit 750
connection plar 199
no shutdown
impedance 600r
description Jackie's Line ***-***-****
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
caller-id enable
caller-id alerting ring 1
no caller-id alerting dsp-pre-allocate
voice-port 0/0/1
trunk-group POTS 2
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
echo-cancel enable
echo-cancel mode 0
vad
compand-type u-law
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timing digit 100
timing pulse 10
timing min-ring 125
connection plar 198
no shutdown
impedance 600r
description Mortimer's Line 212-***-****
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
caller-id enable
voice-port 0/0/2
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
echo-cancel enable
echo-cancel coverage 128
echo-cancel mode 0
vad
compand-type u-law
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timing hookflash-out 400
timing digit 100
timing pulse 10
timing min-ring 125
no shutdown
impedance 600r
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
no caller-id enable
voice-port 0/0/3
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
echo-cancel enable
echo-cancel mode 0
vad
compand-type u-law
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timing digit 100
timing pulse 10
timing min-ring 125
no shutdown
impedance 600r
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
no caller-id enable
voice-port 0/1/0
trunk-group POTS 1
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
echo-cancel enable
echo-cancel mode 0
vad
compand-type u-law
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timing digit 100
timing pulse 10
timing min-ring 125
connection plar 197
no shutdown
impedance 600r
description Staff Line 1 212-***-****
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
caller-id enable
voice-port 0/1/1
trunk-group POTS 4
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
echo-cancel enable
echo-cancel mode 0
vad
compand-type u-law
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timing digit 100
timing pulse 10
timing min-ring 125
connection plar 196
no shutdown
impedance 600r
description Staff Line 2 212-***-***
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
caller-id enable
voice-port 0/1/2
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
echo-cancel enable
echo-cancel mode 0
vad
compand-type u-law
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timing digit 100
timing pulse 10
timing min-ring 125
no shutdown
impedance 600r
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
no caller-id enable
voice-port 0/1/3
no supervisory sit
pre-dial-delay 1
ring number 1
ani mapping 0 0
ani mapping 1 0
ani mapping 2 0
ani mapping 3 0
no soft-offhook
signal loopStart
dial-type dtmf
no disc_pi_off
input gain 0
echo-cancel enable
echo-cancel mode 0
vad
compand-type u-law
no local-alerting
comfort-noise
cptone US
timeouts initial 15
timing digit 100
timing pulse 10
timing min-ring 125
no shutdown
impedance 600r
music-threshold -38
threshold noise -62
fax disable
no busyout forced
no busyout graceful
no caller-id enable
ccm-manager switchback graceful
ccm-manager application redundant port 2428
ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager sccp local FastEthernet0/0
mgcp request timeout 500
mgcp request timeout max 4000
mgcp max-waiting-delay 3000
mgcp restart-delay 0
mgcp sched-time 0
mgcp modem passthrough voip codec g711ulaw
mgcp modem passthrough voaal2 codec g711ulaw
mgcp modem relay voip gateway-xid compress both dictionary 1024 string-length 32
mgcp modem relay voip latency 200
mgcp modem relay voip sprt retries 12
mgcp modem relay voip sprt v14 receive playback hold-time 50
mgcp modem relay voip sprt v14 transmit hold-time 20
mgcp modem relay voip sprt v14 transmit maximum hold-count 16
mgcp codec g711ulaw packetization-period 20
mgcp debug-header
mgcp quarantine mode discard step
mgcp ip qos dscp ef media
mgcp ip qos dscp af31 signaling
mgcp quality-threshold lwm-jitter-buffer 30
mgcp quality-threshold hwm-jitter-buffer 150
mgcp quality-threshold lwm-latency 150
mgcp quality-threshold hwm-latency 300
mgcp quality-threshold lwm-packet-loss 1000
mgcp quality-threshold hwm-packet-loss 10000
mgcp playout adaptive 60 40 1000
mgcp playout fax 300
mgcp package-capability gm-package
mgcp package-capability dtmf-package
mgcp package-capability trunk-package
mgcp package-capability line-package
mgcp package-capability hs-package
mgcp package-capability atm-package
mgcp package-capability ms-package
mgcp package-capability dt-package
mgcp package-capability mo-package
mgcp package-capability res-package
mgcp package-capability mt-package
mgcp package-capability md-package
mgcp default-package trunk-package
mgcp package-capability mf-package
mgcp package-capability rtp-package
mgcp package-capability nas-package
mgcp package-capability as-package
mgcp package-capability script-package
mgcp package-capability adsi-package
mgcp package-capability it-package
mgcp package-capability b-package
mgcp package-capability sst-package
mgcp package-capability mdr-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
mgcp package-capability lcs-package
mgcp package-capability mdste-package
mgcp package-capability srtp-package
mgcp package-capability fm-package
mgcp quality-threshold lwm-cell-loss 1000
mgcp quality-threshold hwm-cell-loss 10000
no mgcp timer receive-rtcp
mgcp timer keep-alive 180
mgcp timer net-cont-test 200
mgcp timer nse-response t38 200
mgcp time toh 10000
mgcp piggyback message
mgcp persistent offhook
mgcp fax rate voice
mgcp fax t38 ecm
mgcp fax-relay sg3-to-g3
mgcp explicit hookstate
mgcp rtp payload-type cisco-pcm-switch-over-ulaw 0
mgcp rtp payload-type cisco-pcm-switch-over-alaw 8
mgcp rtp payload cisco-codec-fax-ind 96
mgcp rtp payload cisco-codec-fax-ack 97
mgcp rtp payload-type nse 100
mgcp rtp payload-type nte 99
mgcp dns stale threshold 30
no mgcp disconnect-delay
sccp local FastEthernet0/0 port 2000
sccp ccm 10.0.20.10 identifier 1 priority 1 port 2000 version 5.0.1
sccp ip precedence 5
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODE75STREET
associate profile 2 register CFB75STREET
registration retries 3
registration timeout 10
keepalive retries 3
keepalive timeout 30
connect retries 3
connect interval 10
switchover method graceful
switchback method guard timeout 7200
switchback interval 10
signaling dscp cs3
audio dscp ef
dspfarm profile 1 transcode
description transcoder
codec g711ulaw
codec g711alaw
codec g729r8
no rsvp
maximum sessions 4
associate application SCCP
dspfarm profile 2 conference
description DSPFarm Profile for Conferencing
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum conference-participants 8
maximum sessions 2
dial-peer voice 2 pots
trunkgroup POTS
permission both
description ** incoming pots dial-peer **
no numbering-type
preference 0
no max-conn
capacity update interval 25
information-type voice
incoming called-number .
fax rate system
bandwidth maximum 64
digit-strip
register e164
sip-register
preemption level routine
dial-peer voice 100 pots
trunkgroup POTS
permission both
description dial peer for US LD
no numbering-type
preference 0
no max-conn
destination-pattern 1[2-9]..[2-9]......
fax rate system
digit-strip
forward-digits 11
register e164
sip-register
dial-peer voice 101 pots
trunkgroup POTS
permission both
description dial peer for US Local
no numbering-type
preference 0
no max-conn
destination-pattern [2-9]......
fax rate system
digit-strip
forward-digits 7
register e164
sip-register
dial-peer voice 102 pots
trunkgroup POTS
permission both
description dial peer for  N11
no numbering-type
preference 0
no max-conn
destination-pattern [2-9]11
fax rate system
no digit-strip
register e164
sip-register
dial-peer voice 105 pots
trunkgroup POTS
permission both
description dial peer for US LD unblock CID
no numbering-type
preference 0
no max-conn
destination-pattern *821[2-9]..[2-9]......
fax rate system
digit-strip
forward-digits 14
register e164
sip-register
dial-peer voice 106 pots
trunkgroup POTS
permission both
description dial peer for US Local unblock CID
no numbering-type
preference 0
no max-conn
destination-pattern *82[2-9]......
fax rate system
digit-strip
forward-digits 10
register e164
sip-register
dial-peer voice 109 pots
trunkgroup POTS
permission both
description dial peer for International
no numbering-type
preference 0
no max-conn
destination-pattern 011T
fax rate system
digit-strip
prefix 011
register e164
sip-register
dial-peer voice 1001 voip
permission both
description Inbound leg from CCM
no numbering-type
preference 0
no max-conn
rtp-ssrc mux system
destination-pattern 199
media flow-through
no media transcoder high-density
no media forking
monitor probe
no delay transport-address
rtp payload-type cisco-clear-channel 125
rtp payload-type cisco-cas-payload 123
rtp payload-type cisco-fax-relay 122
rtp payload-type cisco-rtp-dtmf-relay 121
rtp payload-type cisco-codec-fax-ack 97
rtp payload-type cisco-codec-fax-ind 96
rtp payload-type cisco-codec-gsmamrnb 117
rtp payload-type cisco-codec-ilbc 116
rtp payload-type cisco-codec-aacld 114
no rtp payload-type g726r16 dynamic
no rtp payload-type g726r24 dynamic
no rtp payload-type lmr-tone
no rtp payload-type nte-tone
rtp payload-type nte 101
rtp payload-type comfort-noise 19
rtp payload-type cisco-codec-video-h263+ 118
rtp payload-type cisco-codec-video-h264 119
modem passthrough nse payload-type 100 codec g711ulaw  gw-controlled
voice-class codec 1
voice-class h323 1
voice-class sip privacy system
voice-class sip outbound-proxy system
voice-class sip srtp negotiate system
voice-class sip g729 annexb-all system
voice-class sip early-offer forced system
voice-class sip anat system
voice-class sip history-info system
voice-class sip rsvp-fail-policy voice post-alert optional keep-alive interval 30
voice-class sip rsvp-fail-policy voice post-alert mandatory keep-alive interval 30
voice-class sip rsvp-fail-policy video post-alert optional keep-alive interval 30
voice-class sip rsvp-fail-policy video post-alert mandatory keep-alive interval 30
voice-class sip authenticate redirecting-number system
max-redirects 1
session target ipv4:10.0.20.10
session transport system
dtmf-relay h245-signal h245-alphanumeric
req-qos best-effort audio
req-qos best-effort video
acc-qos best-effort audio
acc-qos best-effort video
codec g729r8
text relay protocol system
no fax-relay ecm disable
fax-relay sg3-to-g3 system
fax rate voice
fax nsf AD0051
fax protocol system
icpif 20
expect-factor 10
ip qos dscp ef media rsvp-fail
ip qos dscp ef media rsvp-pass
ip qos dscp af41 video rsvp-none
ip qos dscp af41 video rsvp-pass
ip qos dscp af41 video rsvp-fail
ip qos preemption-priority 0
ip qos defending-priority 0
no ip qos policy-locator voice
no ip qos policy-locator video
no vad
supplementary-service h450.2
supplementary-service h450.7
supplementary-service sip moved-temporarily
supplementary-service sip refer
dial-peer voice 1002 voip
permission both
no numbering-type
preference 0
no max-conn
rtp-ssrc mux system
destination-pattern 198
media flow-through
no media forking
monitor probe
voice-class codec 1
voice-class h323 1
max-redirects 1
codec g729r8
fax rate voice
fax nsf AD0051
fax protocol system
icpif 20
expect-factor 10
no vad
dial-peer voice 1003 voip
permission both
no numbering-type
preference 0
no max-conn
rtp-ssrc mux system
destination-pattern 197
media flow-through
no media forking
monitor probe
voice-class codec 1
voice-class h323 1
max-redirects 1
codec g729r8
fax rate voice
fax nsf AD0051
fax protocol system
icpif 20
expect-factor 10
no vad
dial-peer voice 1004 voip
permission both
no numbering-type
preference 0
no max-conn
rtp-ssrc mux system
destination-pattern 196
media flow-through
no media forking
monitor probe
voice-class codec 1
voice-class h323 1
max-redirects 1
codec g729r8
fax rate voice
fax nsf AD0051
fax protocol system
icpif 20
expect-factor 10
no vad
dial-peer voice 110 pots
trunkgroup POTS
permission both
description dial peer for US LD block CID
no numbering-type
preference 0
no max-conn
destination-pattern *671[2-9]..[2-9]......
fax rate system
digit-strip
forward-digits 14
register e164
sip-register
dial-peer voice 112 pots
trunkgroup POTS
permission both
description dial peer for US local block CID
no numbering-type
preference 0
no max-conn
destination-pattern *67917[2-9]......
fax rate system
digit-strip
forward-digits 13
register e164
sip-register
dial-peer voice 113 pots
trunkgroup POTS
permission both
no numbering-type
preference 0
no max-conn
destination-pattern *67646[2-9]......
fax rate system
digit-strip
forward-digits 13
register e164
sip-register
dial-peer voice 114 pots
trunkgroup POTS
permission both
description dial peer for International block CID
no numbering-type
preference 0
no max-conn
destination-pattern *67011T
fax rate system
digit-strip
prefix *67011
register e164
sip-register
dial-peer hunt 0
dial-peer terminator #
dial-peer outbound status-check pots
dial-peer search type data voice
no call-router h323-annexg
gatekeeper
gk-version 4
ras timeout lrq 30
ras retry lrq 2
no send-cisco-circuit-info
no security izct password
no security match source-ip
no security match alias-address-list
security aaa alias-address
no security error-code detailed
no rrq dynamic-prefixes-accept
no arq reject-unknown-prefix
  arq e164 early-lookup
no arq reject-resource-low
lrq hop-count 6
irq global-request
timer lrq seq delay 5
no timer lrq window
timer irr period 4
timer cluster-element announce 30
no timer cluster-element resource-update
timer server timeout 30
timer server retry 30
no bandwidth check-destination
shutdown
call-history max-size 0
endpoint ttl 1800
  server routing trunk-group
  server routing carrier
  server routing both
  server routing
server registration-port 0
  no server absent reject rrq
  no server absent reject arq
call-manager-fallback
xmltest
xmlschema srst-its.xsd
xmlthread 2
max-conferences 8 gain -6
transfer-digit-collect new-call
transfer-system full-consult
log table retain-timer 15
log table max-size 150
user-locale US
user-locale 1 US
user-locale 2 US
user-locale 3 US
user-locale 4 US
limit-dn 7914 56
limit-dn 7915-12 56
limit-dn 7915-24 56
limit-dn 7916-12 56
limit-dn 7916-24 56
limit-dn 12SP 56
limit-dn 7902 56
limit-dn 7905 56
limit-dn 7906 56
limit-dn 7910 56
limit-dn 7911 56
limit-dn 7912 56
limit-dn 7920 56
limit-dn 7921 56
limit-dn 7925 56
limit-dn 7931 56
limit-dn 7935 56
limit-dn 7936 56
limit-dn 7937 56
limit-dn 7940 56
limit-dn 7941 56
limit-dn 7941GE 56
limit-dn 7942 56
limit-dn 7945 56
limit-dn 7960 56
limit-dn x7960 56
limit-dn 7961 56
limit-dn 7961GE 56
limit-dn 7962 56
limit-dn 7965 56
limit-dn 7970 56
limit-dn 7971 56
limit-dn 7975 56
limit-dn 7985 56
limit-dn anl 56
limit-dn ata 56
limit-dn bri 56
limit-dn CIPC 56
limit-dn none 56
limit-dn vgc-phone 56
timeouts busy 10
timeouts trunkseize 180
timeouts ringin-callerid 8
timeouts transfer-recall 0
rollback ip-switching
rollback pass-unexpected-codec
ip source-address 10.0.1.1 port 2000 strict-match
ip qos dscp cs3 signal
ip qos dscp default service
max-ephones 42
max-dn 144
max-redirect 5
system message primary CM Down
keepalive 30
bulk-speed-dial prefix #
voicemail 400
huntstop channel 0
no huntstop
call-forward busy 400
call-forward noan 400 timeout 24
time-zone 12
time-format 12
date-format mm-dd-yy
banner motd
C
This computer system (including all hardware, software and
peripheral devices) is the property of the Zebenixz
(Zebenixz). Use of this computer system is
for management approved purposes. Zebenixz reserves the
right to monitor the use of the computer system at any time
Use of this computer system constitutes consent to such
monitoring. Any unauthorized access, use or modification of
the computer system can result in disciplinary action,civil
liability, or criminal penalties.
Please refer to the Zebenixz Information Security Policy
48 for more information.
alias exec h help
alias exec lo logout
alias exec p ping
alias exec r resume
alias exec s show
alias exec u undebug
alias exec un undebug
alias exec w where
default-value exec-character-bits 7
default-value special-character-bits 7
default-value data-character-bits 8
line con 0
exec-timeout 60 0
password 7 *****
logging synchronous
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 15 0
password 7 ********
logging synchronous
transport input ssh
scheduler allocate 20000 1000
cns id hostname
cns id hostname event
cns id hostname image
cns image retry 60
netconf max-sessions 4
netconf lock-time 10
netconf max-message 0
event manager scheduler script thread class default number 1
event manager scheduler applet thread class default number 32
event manager history size events 10
event manager history size traps 10
end
Thanks - much better.  Is that output from a show run all?  There looks to be a lot of 'extra' configs.  Anyways, to answer your question, it looks like this router has a CUE module (Cisco Unity Express - ie voicemail) and terminates several POTS lines.  It also has conferencing and transcoding resources configured along with SRST (Survivable Remote Site Telephony iirc - basically failover PBX functionality in case your CUCM server(s) isn't reachable).
You won't be able to replace that functionality with a 3rd party router.  In particular, the CUE, SRST, and DSP resources are proprietary.  I'd be surprised if there wasn't a 3rd party PSTN gateway compatible with CUCM, although I haven't had the pleasure as yet.
will.alvord
Level 5
Level 5
Could you attach a text config file?  That's completely unreadable.
Yeah it's a config all. Wow so I'm stuck with this thing. That's fine. What I'm planning on doing is sticking this router, call manager, Vonage equipment, and all the phones on 1 vlan and have the data run on it's own vlan with it's own router servicing that vlan.
I'm moving over to Meraki switches and router because it's a lot easier to get what I need done. Cisco owns Meraki now so hopefully down the line there will be better integration but for now the Meraki is going to be my border router and it will just be in passthrough mode when it comes to the voice vlan.
Thank's I really apriaciate your help.
daniel espinal
I'm thinking about doing this
Using this set up I won't have to change one thing on the cisco side. All I have to do is set up the voice outbound port on the Meraki as a pass through port so it just forwards traffic on to the net and that's it. I'd also have to set up a trunk so the cordless phones can communicate to the voip system.
thoughts?
