ā08-07-2016 10:03 AM - edited ā03-17-2019 07:45 AM
Hello Community,
We have CME router and IP phones in the company. Internal calls are working fine. My next step is to enable external calling via FXO and want to enable Auto Attendant service.
I have this version of of the 2921 router and CME version:
CME-Router-2921#sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FGL2015113R
4 Gigabit Ethernet interfaces
2 terminal lines
16 Voice FXO interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
Cisco Unity Express 8.6.6 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
CME-Router-2921#sh telephony-service
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
I also attached the logs for the router's flash.
With the versions I have on my CME router and existing files on router's flash, is it possible to enable Auto Attendant services? We just need a simple auto attendant wherein external calls will call in via the FXO ports and they can hear an Auto Attendant that will say a welcome message and giving instruction to the caller.
The simple Auto Attendant feature we need:
1. Welcome message - Saying the Company name and blah blah blah then;
2. Giving instruction message like "If you know the extension you want to reach please dial it now or dial 0 for operator assistance"
What are needed procedures and steps to enable this? Do I need to upload a file of the router?
Please give some sample configuration that I can follow.
Thanks for your help.
Sy
ā10-25-2016 08:00 AM
Dear VCsupport17,
If you have solved this issue then plz give me this solution me too have same problem.
and anyone else have solution then please give me
and tell me first is its supporting this feature or not?
Thankx
ā10-25-2016 11:51 AM
Hi Ankit,
Yes, i resolved my issue.
You just need the "its-CISCO.x.x.x.x.tcl" file. I have attached the file.
Extract the zip file and upload the files on router's flash.
In my case, we customized the welcome message and prompt so we recorded the audio files in .au format with 8khz,8-bit, g711ulaw encoding and rename the audio file to "en_welcome.au" and "en_enter_dest.au". I deleted the default audio prompts (en_welcome.au and en_enter_dest.au) on the flash and uploaded the new recorded audio prompts with the same file names.
Then use the audio-prompt load command to use the new voice prompt you just uploaded on the flash.
Router# audio-prompt load flash:en_welcome.au
Router# audio-prompt load flash:en_enter_dest.au
Here's my current config on my CME:
application
service aa flash:its-CISCO.2.0.3.0.tcl
paramspace english language en
paramspace english index 1
param operator 1000
paramspace english location flash:
paramspace english prefix en
param aa-pilot 900
param welcome-prompt _welcome.au
Then i have dial peers:
dial-peer voice 1004 voip
service aa
destination-pattern 900
session target ipv4:192.168.0.2
incoming called-number 900
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 33 pots
service aa
direct-inward-dial
port 0/3/3
Let me know if you need help.
ā11-10-2017 03:07 AM
Hi every One, I'm a newer at cisco collaboration so I need to configure the CME, for labs, with an AA and B-ACD service. For me the menu is: "welcome to my compagny, to join the sales team tape 1, for IT departement, tape 2, for communication, tape 3 , to join our operator, tape 4 . For the after sales services, tape 5if you know your extension, tape 6.
My question is, is the tcl scripts still the same whatever the options menu ?
ā04-12-2025 07:07 AM
Hi ,
I followed your configuration and the AA is working fine, but we have some issue on the call transfer, when calls are directed to the operator we cant transfer it to any internal number.
ā04-12-2025 09:20 PM
It's better to start a new thread rather than replying to an old one.
