08-18-2011 08:23 AM - edited 03-16-2019 06:33 AM
TOPOLOGY
PSTN--------2811 ROUTER------3550 SWITCH------------------CUCM7(WITH DHCP CONFIGURED FOR IP PHONE)
LAN with IP phone
CUCM7 is giving IP to IP PHones but i will like to setup DATA DHCP on the 2811 router, please what do i need to configure on the switch and router, i tried one just now with ip helper-address but its not working.
08-18-2011 08:38 AM
On the router interdface connected to the switch you will have for example:
interface FastEthernet0/1.212
description Voice VLAN
encapsulation dot1Q 212
ip address 172.16.1.2 255.255.255.0
ip helper-address 172.16.1.1 -----> IP address of the Callmanager (TFTP)
ip flow ingress
interface FastEthernet0/1.222
Description Data VLAN
encapsulation dot1Q 222
ip address 172.16.22.254 255.255.255.0
ip flow ingress
For the PC DHCP, here is the router configuration
ip dhcp pool PC
network 172.16.22.0 255.255.255.0
default-router 172.16.22.254
On the switch, the here is the config:
interface fast x/x
switchport
switchport mode trunk
08-19-2011 01:41 PM
i tried this your config but the PC is still getting IP from the CUCM, what might be wrong?
