Need help to calculate bandwidth utilization for VOIP calls
gshrivastava
Hi All,
The environment I am working has Multisite WAN with centralized call processing structure. We have call managers at Delaware and have around 10 remote sites. I need to figure out the bandwidth utilization of calls in remote site. We are also using tools like MRTG, MAZU, RTMT.
Please tell me how to calculate b/w utilization for remote site in such scenario. Also guide me if these tools can be of any use in calculating b/w.
10 Replies 10
I appriciate your quick response Muhammad, but its gonna give me only per call consumption. I need to find the b/w consumtpion of remote site router for voice calls.
It depends on the usage and number of users on each site. There might be some statistics formula depending on the input but mainly we decide bandwidth on best practices.
You should be able to use NBAR to look at the RTP and RTCP to see what the throughput is.  Depending on what protocols and Codecs you are using you could then take the bandwidth consumed and divide it by the bandwidth required per call for the codec.  That would tell you how many calls are required for each time sampling.  You could also look at your BCHA in CDR.  Figure once you know how many calls are going take that times the bandwidth.  Decide how much variance you will need and make your adjustments from there.
You could also use your QoS policy to see in a periond how many packets are matched. I've never confiugred this to be automated, but I'm guessing someone could figure it out in a day or two.
There are products from third party vendors that will help you accomplish this as well, I know Solar Winds has a VoIP plugin.
Hi Ahochau,
I tried NBAR and captured the data. There is a huge count in unknown protocol. I need to figure out b/w utilization for VOIP calls only. I have totaled byte count of VOIP protocols Skinny and MGCP mentioned there. Is that sufficient or do I need to add some other protocols data as well to get the actual b/w utilization by VOIP calls?
Below is the data that I have collected:
                            Input                    Output
   Protocol                 Packet Count             Packet Count
                            Byte Count               Byte Count
                            30sec Bit Rate (bps)     30sec Bit Rate (bps)
                            30sec Max Bit Rate (bps) 30sec Max Bit Rate (bps)
   skinny                   176                      306
                            9148                     14976
                            1000                     2000
                            1000                     2000
   secure-http              0                        55
                            0                        10711
                            0                        1000
                            0                        1000
   rtp                      1                        177
                            44                       7632
                            0                        1000
                            0                        1000
   http                     0                        12
                            0                        3854
                            0                        0
                            0                        1000
   ssh                      26                       10
                            1872                     936
                            0                        0
                            0                        0
   icmp                     11                       15
                            968                      1434
                            0                        0
                            0                        0
   mgcp                     24                       12
                            1080                     700
                            0                        0
                            0                        0
   winmx                    5                        2
                            663                      194
                            0                        0
                            0                        0
   snmp                     2                        1
                            540                      284
                            0                        0
                            0                        0
   bgp                      4                        4
                            214                      206
                            0                        0
                            0                        0
   syslog                   0                        2
                            0                        266
                            0                        0
                            0                        0
   ntp                      1                        1
                            100                      78
                            0                        0
                            0                        0
   netbios                  0                        1
                            0                        95
                            0                        0
                            0                        0
   unknown                  4180                     3204
                            513124                   362370
                            35000                    28000
                            42000                    31000
   Total                    4430                     3802
                            527753                   403736
                            36000                    32000
                            43000                    36000
RTP is the actual media stream, MGCP, SCCP, H323 and SIP would be control protocols.  That doesn't look like enough traffic for an actual phone call.  How may packets is your voice priority queue matching?
HI Ahochau,
It might be because I ran NBAR during non-business hours. Now I have cleared the counters on multilink interface and applied NBAR on the same during peak-business hours. After 15 mins I collected the data, which is attached. Please let me know your finding about voice data utilization in those 15 mins and how to do that.
You were using 8MB worth of bandwidth for rtp between when you cleared the counters and took your snap shot.  Another 700 KB ish was being used for control traffic.  Take your bytes/time and you have your average.  The RTP is really what your are interested as the control will be a fraction of that.  Since NBAR is polling the right data, you should now be able to graph the traffic over time if one of your applications can read NBAR.  I've never configured any of those and don't have time to learn a new application today.  I think CACTI can read NBAR as well. A graphing tool will serve you well here.Also use CDR to figure out your BHCA.  Take the number of calls in the busiest hour times the bandwidth consumed by the codec with overhead and then add 10% and that should tell you how much bandwidth is required.  Compare that to what is being consumed and away you go.  But you really want to find a tool to graph the traffic.
Hi Ahochau,
I got how you calculated the RTP data usage, but didnt get for control traffic.What specific details I need to add to get for control traffic? Can you tell me that?
RTP is the media stream.  RTCP is the control stream for the RTP.  H323, SCCP, MGCP and SIP are all for signaling so I lumped them all in the "control" group with RTCP as any of those would be part of your voice bandwidth.
