ā01-13-2014 07:26 AM - edited ā03-16-2019 09:13 PM
Some one help to identify logtime unused voicemail numbers in CUC.
ā01-13-2014 07:30 AM
Please refer to this thread might help you.
https://supportforums.cisco.com/docs/DOC-13233
Br,
Nadeem
Please rate all useful post.
ā01-13-2014 07:32 AM
Hi Sreenivasulu,
For Unity Connection
There is a perfect tool for this type of report. We have used this to search for the same "setup" info
Check the "Set for First Time Enrollment" and "Voice name Recorded";
Connection User Data Dump (CUDD) Tool
The Connection User Data Dump (CUDD) is a Windows-based remote database administration tool available on the Cisco Unity Tools website. CUDD allows you to export specific information about users to a file that can be viewed or imported into another application, such as a database utility or Microsoft Excel. When the data is exported, the tool automatically creates a header row that lists the data type found in each column of the output, for ease of import into other programs.
Here is a sample (where the 0 under first Time Enrollment means the user has
completed the setup and 1 means they have not gone through the Enrollment steps)
DISPLAY_NAME | PRIMARY_EXTENSION | SET_FOR_FIRST_TIME_ENROLLMENT |
Rob Huffman | 7001 | 0 |
Ben Nutball | 6813 | 1 |
Or maybe you would want to check; from CUDD;
Time of Last Call. Indicates the date and time the user called in to check messages last. This can be handy for finding out which boxes have not been accessed at all or which ones have not been accessed in a long time. This value is in GMT and not your local time, keep that in mind.
The tool is available from the "Superb" Unity Tools site;
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
And for unused mailboxes;
Tools > Reports > Unused Voice Mail Accounts Report .
Cheers!
Rob
***EDIT - +5 to my friend Nadeem for his good info
"Seek it out and ye shall find "
- OneRepublic
