Need help with configuring 3550 for home lab
wgregoryjr
I've started to setup a home IPT lab to try learn a little about Unified Communications a little more.  I'm having problems with getting my 3550 switch configured properly to get IP phones to register properly.
I have a dedicated machine that has ESXI 5.0 installed on it.  I have 4 virtual machines installed on the ESXI server.  CUCM (Pub), CUCM (Sub), Unity Connection, and Presence.
My topology is as follows:
Internet
DSL Modem (192.168.2.1)
Linksys Router  (192.168.3.1)
Linksys assigns DHCP from 192.168.3.2 -> 192.168.3.19)  (All my home devices, other pc's, etc....)
My desktop PC is static 192.168.3.20
The 3550 (vlan 1) is static 192.168.3.50.
   -  Port f0/1 connects to esxi server which houses all the UCM
   -  Port f0/2 connects to 7940 phone I have configured in CUCM
   -  Port f0/24 connects back to my Linksys (home network)
The ESXI server is static 192.168.3.200
The CUCM (Pub) is static 192.168.3.201
The CUCM (Sub) is static 192.168.3.202
The UC (Pub) is static 192.168.3.211
The CUP (Pub) is static 192.168.3.221
per above, all of this is on the same subnet (I'm assuming that's ok).  My softphone that I installed on my desktop came up and registered with no problems but my hardphones are not registering.  Can someone help me with how I need to configure the switch (3550)?
Thanks.
19 Replies 19
still no luck.
to avoid confusion, here are portions of config again.
mls qos
ip subnet-zero
ip routing
no ip domain-lookup
ip dhcp excluded-address 192.168.3.1 192.168.3.20
ip dhcp excluded-address 192.168.3.200 192.168.3.254
ip dhcp pool phone
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   option 150 ip 192.168.3.201
interface FastEthernet0/1  (connected to my ESXI server)
switchport mode dynamic desirable
interface FastEthernet0/2  (connected to the 7940 phone)
switchport mode access
switchport voice vlan 1
mls qos trust device cisco-phone
mls qos trust cos
spanning-tree portfast
interface FastEthernet0/24  (connected back to linksys home router)
no cdp enable
I've tried using DHCP on phone and static assign on phone and phone still not registering.
Can you ping the IP address of the phone from CUCM server?
Is CUCM server defined with IP address or hostname under CUCM Server configuration under System --> Servers?
What does the staus log on the phone show?
Was this phone used recently with another CUCM 8.0+ system? If so delete ITL certificate.
Chris
Yes, ping successful from CUCM
Servers defined with hostnames.
Status message on phone says DNS timeout. Do I need to change the servers to ip addresses?
It's working now.
Thanks so much for your assistance.
You have int fas 0/2 in VLAN 20
VLAN 20 has no DHCP scope or routing.
You will need to build these in something like
vlan 20
name PHONES
int vlan 20
desc *** LAYER3 FOR PHONES ***
ip address 192.168.20.1 255.255.255.0
no shut
ip dhcp excluded-address 192.168.20.1 192.168.20.20
ip dhcp excluded-address 192.168.20.200 192.168.20.254
ip dhcp pool PHONES-VLAN20
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
!also change your phone port config so that your pattop/pc works in
!the PC port too.
int fas 0/2
shut
desc *** PHONE & PC **
switchport host
swithcport voice vlan 20
switchport access 1
mls qos trust cos
no shut
Alex
Regards, Alex. Please rate useful posts.
