05-17-2019 02:28 PM
Hello all and thanks for your time and expertise. Here's my scenario. I have two DIDs that need to be answerable on three clerks' phones. In other words, these clerks needs to answer calls from both DIDs and if one of the clerks is busy - the call should forward to an available clerk. Should I just map these DIDs to DNs in Translation Patterns and then configure Lines for each of the DNs of the clerks' phones? Anyway, just looking for the best way to handle this. Much appreciated.
05-17-2019 02:34 PM
You can just use shared lines.
05-17-2019 11:09 PM
You may set the (same) lines on each phone (shared Line). Just make sure that you will adjust the maximum number of calls and busy trigger to avoid receiving "Busy" when someone has already picked-up one call.
George
05-19-2019 02:54 AM
Create a Line Group with Distribution Algorithm as "Broadcast"
Add clerk's DN's to the line group and make a Hunt List/Pilot
Translate both MSN/DID to Hunt Pilot
05-19-2019 11:46 PM
