09-21-2012 12:24 PM - edited 03-16-2019 01:20 PM
Need to provision Voicemail Redundancy for 350 VM users using Cisco Unified Messaging gateway and CUE8.6 at Remote Site
HQ Site: Cisco Unity Connection8.6
At Branch Site: on Voice Gateway 3925 ISR, SM-SRE-700-k9 used for CUE8.6
Cisco 3925 comes with two Service Module slots. In this case, one SM slot is used by CUE8.6 and the second SM Slot need to be
factored for Cisco UMG (Unified Messaging Gateway).
When we take the spare part code: SM-SRE-700-k9=, under this select Unifed Messaging 8.6 option(SUMG-SM7-86-k9), it later ask to
select Feature license UMG Lic for 25E-SRST nodes/sites quantity. Waht is this required for since we are looking for SRSV and not E-SRST
What should be the correct part code for unified messaging gateway using SM-SRE-700-K9
Best Regards
Sumit
Solved! Go to Solution.
09-22-2012 01:45 PM
09-21-2012 01:09 PM
Your best bet to ask pre-sales questions is to go here:
https://communities.cisco.com/index.jspa#
However, notice that SRSV capability of UMG has been annoucned EOS/EOL and the last day to order the product was
June 18, 2012:
HTH,
Chris
09-22-2012 11:20 AM
Hi Chris,
If SRSV has been declared EOL/EOS then if Voicemail redundancy is required using UMG8.6, then what is the replacement for SRSV or is it that SRSV functionality has been incorporated into E-SRST license?
Sumit
09-22-2012 11:23 AM
Review the announcement, it will eventually be embedded in UNity Connection.
09-22-2012 11:44 AM
So if I understand correct...... currently, Cisco UMG8.6 would only support E-SRST functionality and not voicemail redundancy since SRSV has been declared EOS/EOL.
So, another way to ensure Voicemail Redundancy could be running using Unity Connection (Active/Active) on two separate/diff UCS C210-M2 servers
Sumit
09-22-2012 01:45 PM
Correct.
HTH, please rate all useful posts!
Chris
09-22-2012 03:35 PM
Thank You Chris for sharing the details :-)
Thanks & regards
Sumit
