IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5886 Views
  • 14 replies
Hi ,I am doing a upgrade from CUCMv7 to CUCM8. I have restored the configuration version 7 through DRS, and was sucessfull. So, I installed the upgrade file in the server to install the CUCMv8, and was installed. Now I have in the CUCMv7 in the activ...
                   Sorry if this is a dumb question.  Since CUBE is an SBC, should inbound calls arrive on one interface and outbound calls go out on another?  That is to say, shouldn't one interface be in the DMZ facng the PSTN and the other on the ...
kpstross by Level 1
  • 2256 Views
  • 13 replies
Hello All,When we make change to End User in CUCM (e.g. change user's IPCC extension) it is not reflecting those changes in RMCM Resources under UCCX. Tried to delete user ( removing IPCC ext) in CUCM and user still exist under RMCM rather than Inact...
Resolved! qsig trunk
i am integrating cisco cme with nec pbx. can able to call from cisco to  nec pbx.but couldnt call from nec pbx to cisco.see the debug when call  made from nec to cisco.cme#debug isdn errorcme#052409: Sep 20 23:33:25.351: ISDN Se0/2/0:15 SERROR: proce...
Hi,I have a client that when receive a incoming call from PSTN, both fixed and mobile phone, all are choppy.There is a CME with 1 E1, and 1 BRI,Some alarms in the logs are:GigabitEthernet0/0 is up, line protocol is up  Hardware is BCM1125 Internal MA...
Hello all. I'm working on my VOIP lab and running into a problem. This is my first attempt at VOIP so I'm really green.I am running IOS: c3725-ipvoice-mz.124-25d.binI'm trying to use the 3725 as a TFTP server for the phones. I have DHCP set up on my ...
