Need to retrieve call information
shirwaziri1_2
We have a client. THey are a highschool. Someone made a call to 911 at exactly 12:08 pm. I am trying to identify and get the call information. I need to try to identify who made that call. Well at least from which ip phone extension.
We are running call manager 4.0.2. Any assistance will help.
Thank you
Majdi Harb
Level 3
Level 3
u can use (RTMT) a client side standalone plugin runs as an application using HTTP and TCP to monitor a set of management objects that are preconfigured, it also can generates daily reports and u can view syslogs for these objects from within is the call activities.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ed19a.html#1201672
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ed151.html
hth
please remember to rate helpful posts
/majdi
Rob Huffman
Hi Shir,
Here is an example that shows tracing 911 calls;
Using SQL Queries to Search the Call Detail Record with Cisco CallManager
Search for Calls Made to a Specific Number
In some situations, you might need to find out the extension which called 911 on a specific date. Complete these steps in order to search for calls made to a specific number such as 911.
In order to search for calls that are made to a specific number, you can run a different query.
For example, if you want to look for calls to 911 you can enter the query select * from CallDetailRecord where finalcalledpartynumber='911'.
The bottom of the page displays all the entries in the CDR that have the final called party number equal to 911.
Add a date to this query in order to refine it.
For example, for all calls to 911 after August 1st, 2003, run the query select * from CallDetailRecord where finalcalledpartynumber='911' and datetimeconnect > '1059696000'.
The bottom of the page displays all the entries in the CDR that have the final called party number equal to 911 made after August 1st, 2003. '1059696000' is the universal time in seconds for August 1st, 2003.
In order to see who calls 911, run the query select callingpartynumber from CallDetailRecord where finalcalledpartynumber='911'.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d71c5.shtml
Hope this helps!
Rob
mickeyhunt
Open your CCM log for that time frame and do a search for 911 and it will show you the extension of the caller.
