07-18-2018 04:13 AM - edited 03-17-2019 01:13 PM
We have new installation for PRI line. we have ISR4321 router and NIM-2MFT-T1/E1 - T1/E1 Serial Module with PVDM 64 installed.
Router#sho inventory
NAME: "Chassis", DESCR: "Cisco ISR4321 Chassis"
PID: ISR4321/K9 , VID: V04, SN: FDO2225A2QT
NAME: "Power Supply Module 0", DESCR: "110W AC Power Supply for Cisco ISR 4320"
PID: PWR-4320-AC , VID: , SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4320 Fan Assembly"
PID: ACS-4320-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4321 Built-In NIM controller"
PID: ISR4321/K9 , VID: , SN:
NAME: "NIM subslot 0/2", DESCR: "NIM-2MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-2MFT-T1/E1 , VID: V05, SN: FOC222339CG
NAME: "subslot 0/2 db module 0", DESCR: "PVDM4-64 Voice DSP Module"
PID: PVDM4-64 , VID: V02, SN: FOC222314YE
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 ports Gigabitethernet Module"
PID: ISR4321-2x1GE , VID: V01, SN: JAB092709EL
NAME: "module R0", DESCR: "Cisco ISR4321 Route Processor"
PID: ISR4321/K9 , VID: V04, SN: FDO22241V8Y
NAME: "module F0", DESCR: "Cisco ISR4321 Forwarding Processor"
While configuring on router how we will determine card type e1 command? ie slot and subslot?
can some body explain it? from the above inventory how will i determine slot and subslot?
07-18-2018 04:39 AM
yes i got it.
this is what we need to check
so command will be
card type e1 0 2
07-18-2018 05:40 AM
That is correct.
07-18-2018 05:42 AM
you can also refer the below link with Table 1.6 for details
regds,
aman
