No caller ID showing on desk phones
DOUGLAS DRURY
Hi All,
I have a strange issue that I can't seem to get to the bottom of.  When the CME receives an incoming call users can only see 90 on there desk phones.  I've looked back at my other configs but can't seem to see when the issue is.  caller ID works for internal calls.
GJ-CME-01#sh run brief
Building configuration...
Current configuration : 13282 bytes
! Last configuration change at 14:27:46 UTC Sat Aug 2 2014 by tsadmin
version 15.2
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service internal
service sequence-numbers
hostname GJ-CME-01
boot-start-marker
boot-end-marker
logging queue-limit 10000
logging buffered 10000000
logging rate-limit 10000
no logging console
no logging monitor
enable secret 5 $1$lx04$m.jUoK8kxvjUxyfqvcaa7/
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
ip cef
ip dhcp excluded-address 192.168.30.1 192.168.30.9
ip dhcp excluded-address 192.168.30.201 192.168.30.254
ip dhcp pool CME
 import all
 network 192.168.30.0 255.255.255.0
 domain-name JACKS.local
 dns-server 192.168.30.1
 option 150 ip 192.168.30.1
 default-router 192.168.30.1
 lease 0 10
ip domain name jacks.local
no ipv6 cef
isdn switch-type vn3
trunk group GJ_ISDN_Trunk_Group
 hunt-scheme least-idle
crypto pki trustpoint TP-self-signed-2056135179
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2056135179
 revocation-check none
 rsakeypair TP-self-signed-2056135179
crypto pki certificate chain TP-self-signed-2056135179
 certificate self-signed 01
voice-card 0
voice iec syslog
voice hunt-group 1 parallel
 final 2002
 list 7407,7405,7406,7408
 timeout 10
 pilot 2001
voice hunt-group 2 parallel
 final 7497
 list 7401,7402,7403,7404
 timeout 10
 pilot 2002
voice translation-rule 1
 rule 1 /^.*/ /516099/
voice translation-rule 2
 rule 1 /^516099$/ /2001/
voice translation-rule 4
 rule 1 // /0/
voice translation-rule 5
 rule 1 // /90/
voice translation-profile Inbound
 translate calling 5
 translate called 2
voice translation-profile Outbound_CALLER_ID_516099
 translate calling 1
license udi pid CISCO2901/K9 sn FCZ1815C4W4
license accept end user agreement
hw-module ism 0
hw-module pvdm 0/0
username tsadmin privilege 15 secret 5 $1$0Bw9$2WIgb0Ejv29NY7HdTFn5I1
redundancy
 notification-timer 60000
no ip ftp passive
ip ftp source-interface GigabitEthernet0/0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 description Managment from Data LAN
 ip address 192.168.20.203 255.255.255.0
 duplex auto
 speed auto
interface ISM0/0
 description Unity-Express-Moduale
 ip unnumbered GigabitEthernet0/1
 ip virtual-reassembly in
 service-module ip address 192.168.30.2 255.255.255.0
 !Application: CUE Running on ISM
 service-module ip default-gateway 192.168.30.1
interface GigabitEthernet0/1
 description VOICE_LAN
 ip address 192.168.30.1 255.255.255.0
 duplex auto
 speed auto
interface ISM0/1
 description Internal switch interface connected to Internal Service Module
 no ip address
interface BRI0/0/0
 description GJ_ISDN_1
 no ip address
 isdn switch-type basic-net3
 isdn tei-negotiation first-call
 isdn point-to-point-setup
 isdn incoming-voice voice
 isdn static-tei 0
 trunk-group GJ_ISDN_Trunk_Group
interface BRI0/0/1
 description GJ_ISDN_2
 no ip address
 isdn static-tei 0
interface BRI0/1/0
 description GJ_ISDN_3
 no ip address
 isdn static-tei 0
interface BRI0/1/1
 description GJ_ISDN_4
 no ip address
 isdn static-tei 0
interface Vlan1
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip route 0.0.0.0 0.0.0.0 192.168.20.254
ip route 192.168.1.0 255.255.255.0 192.168.20.254
ip route 192.168.30.2 255.255.255.255 ISM0/0
logging trap debugging
tftp-server flash:term41.default.loads alias term41.default.loads
tftp-server flash:term61.default.loads alias term61.default.loads
tftp-server flash0:/Phone/SCCP7942/SCCP42.9-2-1S.loads
tftp-server flash0:/Phone/SCCP7942/apps42.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7942/cnu42.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/dsp42.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7942/cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7942/dsp42.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7942/jar42sccp.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7942/term42.default.loads
tftp-server flash0:/Phone/SCCP7942/term62.default.loads
tftp-server flash0:/Phone/SCCP7961/SCCP41.9-2-1S.loads
tftp-server flash0:/Phone/SCCP7961/apps41.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7961/cnu41.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7961/cvm41sccp.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7961/dsp41.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7961/jar41sccp.9-2-1TH1-13.sbn
tftp-server flash0:/Phone/SCCP7961/term41.default.loads
tftp-server flash0:/Phone/SCCP7961/term61.default.loads
tftp-server flash:RingList.xml
tftp-server flash:Cisco-synth.raw
tftp-server flash:Cisco-synth.au
tftp-server flash:Desktops/320x196x4/TN-gj.png
tftp-server flash:Desktops/320x196x4/List.xml
tftp-server flash:Desktops/320x196x4/gj.png
control-plane
voice-port 0/0/0
 compand-type a-law
 cptone GB
 timeouts interdigit 0
voice-port 0/0/1
 compand-type a-law
 cptone GB
voice-port 0/1/0
 compand-type a-law
 cptone GB
voice-port 0/1/1
 compand-type a-law
 cptone GB
mgcp profile default
dial-peer voice 7499 voip
 destination-pattern 7499
 session protocol sipv2
 session target ipv4:192.168.30.2
 dtmf-relay sip-notify rtp-nte sip-kpml
 codec g711ulaw
 no vad
dial-peer voice 800 voip
 destination-pattern 800.....
 codec g711ulaw
 no vad
dial-peer voice 8000 voip
 codec g711ulaw
 no vad
dial-peer voice 4 pots
 trunkgroup GJ_ISDN_Trunk_Group
 description Main_Line_Inbound
 translation-profile incoming Inbound
 incoming called-number 516099
 direct-inward-dial
dial-peer voice 3 pots
 description UK_Mobile_Outgoing
 translation-profile outgoing CALLER_ID_516099
 destination-pattern 907[1-9]........
 forward-digits 11
dial-peer voice 6 pots
 description UK_6Dig_Local_Outgoing
 destination-pattern 9[2-9].....
 forward-digits 6
dial-peer voice 7 pots
 description UK_11Dig_National_Outgoing
 destination-pattern 90[1-3].........
 forward-digits 11
dial-peer voice 8 pots
 description UK_11Dig_0800_Outgoing
 destination-pattern 9080[08].......
 forward-digits 11
dial-peer voice 9 pots
 description UK_999_Outgoing
 destination-pattern 9999
 forward-digits 3
dial-peer voice 10 pots
 description Unmatched_Default_Pattern
 destination-pattern 9T
dial-peer voice 11 pots
 description UK_11Dig_0845_Outgoing
 destination-pattern 90845.......
 forward-digits 11
dial-peer voice 12 pots
 description UK_11Dig_0870_Outgoing
 destination-pattern 90870.......
 forward-digits 11
dial-peer voice 20 pots
 direct-inward-dial
gatekeeper
 shutdown
telephony-service
 no auto-reg-ephone
 authentication credential tsadmin L3monsolE
 pin 123456
 max-ephones 10
 max-dn 15
 ip source-address 192.168.30.1 port 2000
 max-redirect 7
 service dnis dir-lookup
 timeouts interdigit 5
 system message G&J Jack FR Ltd
 url services http://192.168.30.2/voiceview/common/login.do
 url authentication http://192.168.30.1/CCMCIP/authenticate.asp
 cnf-file location flash:
 load 7942 SCCP42.9-2-1S
 date-format dd-mm-yy
 voicemail 7499
 max-conferences 8 gain -6
 hunt-group logout HLog
 moh "flash:/MOH/Cisco_CallManagerOHM.au"
 multicast moh 239.1.1.1 port 16384 route 192.168.20.203 192.168.30.1
 web admin system name tsadmin secret 5 $1$4JJ6$yhxjz8DOEq5Oz13EOe.cU.
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn-template  1
 call-forward busy 7499
 call-forward noan 7499 timeout 18
 mwi on
ephone-template  1
 softkeys hold  Resume Newcall Select
 softkeys idle  Gpickup Dnd Cfwdall Redial Newcall
 softkeys seized  Redial Endcall Cfwdall Pickup Gpickup Callback
 softkeys alerting  Acct Callback Endcall
 softkeys connected  Hold Trnsfer Endcall
ephone-dn  1  dual-line
 number 7402
 pickup-group 1
 label Ext -7402
 description George Jack
 name George Jack
 call-forward noan 7499 timeout 10
ephone-dn  2  dual-line
 number 7401
 pickup-group 1
 label Ext -7401
 description Martin Jack
 name Martin Jack
ephone-dn  3  dual-line
 number 7403
 pickup-group 1
 label Ext -7403
 description Jason Jack
 name Jason Jack
ephone-dn  4  dual-line
 number 7404
 pickup-group 1
 label Ext -7404
 description Steven Maclean
 name Steven Maclean
ephone-dn  5  dual-line
 number 7405
 pickup-group 1
 label Ext -7405
 description Pam Manett
 name Pam Manett
ephone-dn  6  dual-line
 number 7406
 pickup-group 1
 label Ext -7406
 description Ashley Reid
 name Ashley Reid
ephone-dn  7  dual-line
 number 7407
 pickup-group 1
 label Ext -7407
 description Carol Angus
 name Carol Angus
ephone-dn  8
 number 1
 name All
 paging ip 239.0.0.1 port 2000
ephone-dn  9
 number 8000....
 mwi on
ephone-dn  10
 number 8001....
 mwi off
ephone-dn  11  dual-line
 number 7408
 label Ext -7408
 description Logistics
 name Logistics
ephone-dn  12  dual-line
 number 0000 secondary 7497
 label Ext - 0000
 description Unity GDM
 name Unity GDM
ephone  1
 mac-address 5017.FF96.3988
 ephone-template 1
 username "Mjack" password 123456
 paging-dn 8
 type 7945
 button  1:2
 pin 123456
ephone  2
 mac-address 5017.FF96.3A13
 ephone-template 1
 username "Cangus" password 123456
 paging-dn 8
 type 7942
 button  1:7
 pin 123456
ephone  3
 mac-address 5017.FF97.159C
 ephone-template 1
 username "Pmanett" password 123456
 paging-dn 8
 type 7942
 button  1:5
 pin 123456
ephone  4
 mac-address 5017.FF96.3A12
 ephone-template 1
 username "Areid" password 123456
 paging-dn 8
 type 7942
 button  1:6
 pin 123456
ephone  5
 mac-address 5017.FF96.4050
 ephone-template 1
 username "Smaclean" password 123456
 paging-dn 8
 type 7942
 button  1:4
 pin 123456
ephone  6
 mac-address 7C95.F323.DE2D
 ephone-template 1
 username "Jjack" password 123456
 paging-dn 8
 type 7942
 button  1:3
 pin 123456
ephone  7
 mac-address 5017.FF96.390F
 ephone-template 1
 username "GJack" password 123456
 paging-dn 8
 type 7942
 button  1:1
 pin 123456
ephone  8
 mac-address 5CA4.8A65.0DDB
 username "logistics" password 123456
 type 7942
 button  1:11
 pin 123456
ephone  9
 mac-address 623B.1C82.8C1E
 username "GDM"
 type CIPC
 button  1:12
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
line vty 0 4
 exec-timeout 0 0
 privilege level 15
 login local
 transport input telnet ssh
 transport output telnet ssh
scheduler allocate 20000 1000
end
GJ-CME-01#
5 Replies 5
d.bigerstaff
 translate calling 5 <--- This is applied to the calling number
 translate called 2
voice translation-rule 5 <--- Which is this rule
 rule 1 // /90/
It looks like that rule is replacing whatever the number is with 90. Are you trying to just prefix a 9 on the calling number so it's easy to redial?
Take a read of this which I think will help - https://supportforums.cisco.com/discussion/11576951/voice-translation-rule-prefix
Yes 9 is prefixed to make it easier to redial.  The bit I'm confused by is I've managed to achieve this before using the same translation.
// /90/ should work to prefix 90 onto whatever number your telco is sending you. Perhaps they aren't sending caller digits. I would check with your telco to make sure the feature is enabled.
-Jameson
-Jameson
I would also verify the service is enabled with the carrier and if not have them add it to the BRI channel. I have found this to not be uncommon. We would think that caller id is enabled by default, but many carriers still offer it separately as a billable feature.
Turn on some debugs and see what you get.
debug vpm signal
Please rate useful posts and mark answers as correct if applicable.
Give it a test with the following handy command
GJ-CME-01#test voice translation-rule 5 01891613513
The output after that should show you the original number and the translated number.
