10-13-2011 05:56 PM - edited 03-16-2019 07:30 AM
I have 1861 router and running telephony on it. There is no enough memory so I can not add a new dial-peer on it.
I want to upgrade it, but not sure if I have to buy the memory or just IOS upgrade would do.
The current IOS version is :
Cisco IOS Software, C1861 Software (C1861-ADVIPSERVICESK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
System image file is "flash:c1861-advipservicesk9-mz.151-1.T.bin"
#sh memory
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 86D8E500 140974848 127783508 13191340 12933008 12830160
I/O F400000 12582912 6633960 5948952 5838432 5835612
Can anyone please guide what to upgrade.
Solved! Go to Solution.
10-15-2011 10:24 AM
Seems like you have plenty of memory already.
10-15-2011 05:05 PM
The IOS you are requires 256M DRAM & 128M FLASH
However this releas has been deferred by Cisco due to software bugs.
To remain in this train you should upgrade to :-
c1861-advipservicesk9-mz.151-1.T3.bin or to the latest release
c1861-adventerprisek9-mz.151-3.T2.bin
Both of these require 256M DRAM & 128M FLASH
Alex
10-15-2011 10:24 AM
10-16-2011 04:25 PM
Hi Paolo,
I have deleted the POTS dial-peer which are not in use. But still I can't add any thing. Getting error " Could not add peer".
10-15-2011 05:05 PM
Alex
10-16-2011 04:23 PM
Hi Alex,
Thank you very much for your help and replying.
Do I have to buy the memory also.
Rachna
10-16-2011 04:28 PM
Rachna,
Please supply the output of "show version"
I will be able to tell from that whether you need more memory and what kind
Alex
10-16-2011 06:49 PM
Hi Alex,
Please see the details
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Mar-10 00:51 by prod_rel_team
Cisco C1861-UC-4FXO-K9 (MPC8358) processor (revision 0x202) with 249856K/12288K bytes of memory.
Processor board ID FHK131820RQ
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
12 User Licenses
10 FastEthernet interfaces
1 ATM interface
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
2000880K bytes of ATA CompactFlash (Read/Write)
Rachna
10-17-2011 06:23 PM
Hi Alex,
On adding a new dial-peer, I am getting error because of less memory:
#conf t
(config)#dial-peer voice 2010 voip
ERROR: could not add peer
Oct 18 01:17:31.494: %DIALPEER_DB-3-ADDPEER_MEM_THRESHOLD: Addition of dial-peers limited by available memory
Rachna
11-01-2011 03:49 PM
I upgraded the router to IOS c1861-advipservicesk9-mz.151-1.T3.bin.
Now I can add dial-peer or ephone-dn or hunt-group without issues.
