Non-Cisco VoIP Phones
zekebashi
Level 4
Level 4
I have a client who has Polycomm VoIP phonse and I'll be deploying Cisco C3650 switches. The phones will be connected to ports on the C3650. I wanted to know if the same port configuration we use with the Cisco VoIP phonse can be used with other non-Cisco VoIP phones. Here's how I intend to configure the ports"
VLAN 916
   name Data
VLAN 917
   name Voice
sw#config t
sw(config)# interface range  G1/0/1 - 15
sw(config-if)# swithcport
sw(config-if)#switchport mode access
sw(config-if)#switchport access vlan 916
sw(config-if)#switchport access vlan voice 917
sw(config-if)#exit
Thanks in advance.
Best, ~zK
2 Accepted Solutions
just configure your data vlan ie acces with mode access command if you plugging your PC on that switch.
Br,
Nadem
Br, Nadeem Please rate all useful post.
+5 Nadeem.
Here just a link on how configure an non Cisco phone on a Cisco switch
https://www.devconnectprogram.com/fileMedia/download/fea323f2-23a2-43a2-a470-ee9999b051e9
Carlo
Please rate all helpful posts "The more you help the more you learn"
7 Replies 7
Nadeem Ahmed
enable the lldp on the switch and 917 suppose to voice vlan. non-cisco phone support lldp when using cisco switches
#lldp run
Thank you, Nadeem.
I'm  assuming that only VoIP phones would be plugged into the port, correct? But, what if we need to configure the port where we can plug a PC only and at other times plug VoIP phones? Which config would be correct?
Thanks, ~zK
Br,
Nadem
+5 Nadeem.
Carlo
Much appreciated.
Best, ~zK
Thanks, Nadem!
Much appreciated.
Best, ~sK
Ronak Agarwal
vlan 916
name DataVlan
vlan 917
name VoiceVlan
interface FastEthernet4/2
 no ip address
 switchport
 switchport access vlan 917
 spanning-tree portfast
refer below link for more details:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/97229-config-cat-switches-polycom.html
Ronak Agarwal
