03-06-2009 06:27 AM - edited 03-15-2019 04:40 PM
I ahve a cucm ver 7.0 we are testing pstn lines at the moment.
When I make an outgoing call, all is fine, if the called party then hangs up, my line is still staying active, then a announcemnt is made that "the other person has hung up" does nayone have any ideas?
03-06-2009 06:32 AM
Where are you located? See:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Note, avoid analog lines as much as possible. Using ISDN will give you all the advantages and notne of the trouble.
03-06-2009 06:45 AM
sorry, I should have said,
It is uk based with standard ISDN 30 connection.
07-30-2009 09:07 AM
I know it's been a few months since this call was raised but I just had a similar issue and resolved it with the 'voice call disc-pi-off' command.
Hope you found this before now.
Paul
