NTP on MPE
jones2sr
How do you configure/start NTP on Meeting Place Express? I keep having to reset the time. Today it was 20 minutes behind and caused all kind of havoc. :P
thisisshanky
Level 11
Level 11
Jones,
From MPX desktop or remote ssh into a shell session on MPX server. Type "net".
A menu with lot of options will show up and then you can choose option 8 to configure NTP service.
Once you change the settings, save it when the menu prompts and reboot the server.
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thisisshanky
Level 11
Level 11
Jones,
Sankar
Sankar Nair
I have done this and it still is not syncing. I can ping the NTP server from the MPX server
I have checked the /etc/ntp.conf and it shows the ntp server listed there as well.
Did you ever get the ntp to sync on mpe?
Yes - we had to log a TAC case to resolve this in the end. We also had to update the MPE version.
