Number of active calls on an H.323 gateway.
nick anderson
Hello all,
A while back I found a really nice command to show the number of active calls on a voice gateway.  Ever since that day I have been trying to figure out what that command was.  I know that it was a show command, and was either a brief or summary.
It output a list of active calls, and included the ANI, DNIS, and Port number of the call.
Does any one know the command I am thinking of?  It was a big help in troubleshooting a trunkgroup issue, and I need to use it again.
dksingh
There are a few CLI for this....not sure
which particular one u r looking for but
I use these pretty often....
show call active voice compact | brief
show isdn active
show voice call stat | summ
show voip rtp connect
5 Replies 5
Jaime Valencia
Maybe show voice call summary?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jonathan Schulenberg
I think you're looking for show call active voice brief.
dksingh
show isdn active
Actually, I was remembering the ouputs of show voice call status and show isdn active.
Thanks very much everyone!
nick anderson
All very useful commands!  Thanks guys.
"Show ISDN active" is the closest to what I remember...  The only thing it is missing is the port number of the B-channel that the call is using.
That may very well mean that I am combining "show isdn active" and "show voice call summ" in my memory.
