11-05-2010 05:45 PM - edited 03-16-2019 01:46 AM
Hello all,
A while back I found a really nice command to show the number of active calls on a voice gateway. Ever since that day I have been trying to figure out what that command was. I know that it was a show command, and was either a brief or summary.
It output a list of active calls, and included the ANI, DNIS, and Port number of the call.
Does any one know the command I am thinking of? It was a big help in troubleshooting a trunkgroup issue, and I need to use it again.
Solved! Go to Solution.
11-05-2010 08:34 PM
There are a few CLI for this....not sure
which particular one u r looking for but
I use these pretty often....
show call active voice compact | brief
show isdn active
show voice call stat | summ
show voip rtp connect
11-05-2010 08:21 PM
Maybe show voice call summary?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
11-05-2010 08:27 PM
I think you're looking for show call active voice brief.
11-05-2010 08:34 PM
show isdn active
11-09-2010 09:43 AM
Actually, I was remembering the ouputs of show voice call status and show isdn active.
Thanks very much everyone!
11-09-2010 09:32 AM
All very useful commands! Thanks guys.
"Show ISDN active" is the closest to what I remember... The only thing it is missing is the port number of the B-channel that the call is using.
That may very well mean that I am combining "show isdn active" and "show voice call summ" in my memory.
