01-02-2011 03:11 AM - edited 03-16-2019 02:39 AM
Hi all,
Any body can help me to understand why I need to use Numbering type and Numbering Plan?
01-02-2011 05:00 AM
A numbering plan identifies each VoIP endpoint and application in the network with a unique telephone number. Numbering plan design should evaluate both current requirements and potential growth requirements to avoid the need to renumber as more users connect to the voice network. There are diffrent types of numbering plans like E.164 plan(International public numbering plan),national numbering plans and private numbering plans. More of this can be read at the link below
http://ciscoarticles.com/Voice-Over-IP/721.html
As far as the number type is concerned, every subscriber in a mobile network is uniquely identified by a mobile station ISDN or public switched telephone network (PSTN) number. The type of Number(TON) is used for many purposes, one of which is for billing the end users.
The TON information is displayed as an attribute-value (AV) pair in the AAA accounting records that are sent to the RADIUS server for billing purposes. The format is as follows:
caller-type-of-number=value
The value can be any of the following, which are specified in the International Telecommunication Union Telecommunication Standardization Sector (ITU-T) specification Q.931 dated March 1993.
•National—refer to ITU-T Recommendation I.330
•International—refer to ITU-T Recommendation I.330
•Subscriber (local)—refer to ITU-T Recommendation I.330
•Network specific—an administrative or service number that is specific to the serving network (for example, a number used to access an operator)
•Unknown—the user or the network has no knowledge of the type of number.
Nitesh
PS: Please rate helpful posts
01-02-2011 01:01 PM
To add to that
The Numbering Plan Indicator (NPI) is a number which is defined in the ITU standard Q.713, paragraph 3.4.2.3.3, indicating the numbering plan of the attached telephone number. NPIs can be found in SCCP and SMS messages. As of 2004 the following numbering plans and their respective Numbering Plan Indicator values have been defined:
NPI Description Standard
0 unknown
1 ISDN Telephony E.164
2 generic
3 data X.121
4 telex F69
5 maritime mobile E.210 and E.211
6 land mobile E.212
7 ISDN/mobile E.214
01-02-2011 01:34 PM
Thank you all for you reply,
Till now I am not able to understand why to use Numbering Plan
Nitesh said one of the puposes is billing.
Does it mean that CDR cotains these information and billing server will take these information and then we can configure billing server to use it?
I need to know more about these purposes
In CUCM I have the following options:
I saw some scenarios where PSTN send these information to CUCM, I think it is only applicable if it is PRI?
but I expect Subscriber (local), National and International from PSTN, So what about Cisco Unified Communication Manager and Unknown?
FOR NUMBERING PLAN, in CUCM help
Options:
I am still confused
01-02-2011 02:08 PM
Could you refer Pg.125
http://books.google.com/books?id=YMas7A3E65MC&lpg=PA124&ots=qy0v_g2awx&dq=Calling%20Party%20Number%20Type%20cisco%20callmanager&pg=PA125#v=onepage&q=Calling%20Party%20Number%20Type%20cisco%20callmanager&f=false
That should clear your doubts about Numbering plan "Cisco CallManager"
I will try to dig more info for you on this..
Usually these type/plan comes into play in Globalization/localization.
Are you aware of these dial plan configs?..
PS: Rate Useful posts.!
01-02-2011 09:20 PM
Thank you too much for your support,
I have this book and I will read and review this part.
regarding globalization and localizattion, yes I am aware of these configs, and numbering type it is very helpful in GW to prefix the incomming calling party.
I will go throgh the book and for sure I am waiting your support, and thanks again
01-02-2011 10:38 PM
Nice...I am happy that it helped.!
Preparing for your ccie is it?. I am also on the same boat
