05-22-2017 08:05 AM - edited 03-17-2019 10:23 AM
This is my first time posting so please forgive any errors. We are experiencing one way audio issues in our newly implemented SIP platform. I came across this thread and think I may be on the right track as to what is going on. I am very new to Cisco Call Manager as most of my experience has been in the Avaya world. Currently, our organization has multiple phone systems and we will be consolidating shortly. For the sake of this comment, I will talk of our Cisco and Avaya as this is where we are experiencing problems.
On the west coast, we have a Cisco Call Manager and on the East Coast, Avaya. We have AT&T SIP trunks in both locations. On the west coast is where I think the problem lies. Our connection is as follows:
Call Manager -> CUBE -> ATT SIP RTR (hope that makes sense)
The problem that we are facing is that west coast users can hear east coast but, east cannot hear west. This happens whether the call is inbound or outbound.
here is my config... are we missing something or is there a misconfiguration that you may see?
interface GigabitEthernet0/0/0
description *** Voice Gateway LAN ***
ip address x.x.x.x 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/1
description TO AT&T_Voice ROUTER
ip address x.x.x.x 255.255.255.248
negotiation auto
router eigrp 100
network x.x.x.x 0.0.0.255
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route x.x.x.x 255.255.0.0 y.y.y.y
ip ssh version 2
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/0
sccp ccm x.x.x.x identifier 1 priority 1 version 7.0
sccp ccm x.x.x.x identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register MTP_CUBE_SCDC
associate profile 2 register CFB_CUBE_SCDC
associate profile 3 register XCODE_CUBE_SCDC
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 3 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 15
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 15
dspfarm profile 1 mtp
codec g711ulaw
codec pass-through
maximum sessions software 150
dial-peer voice 100 voip
description INBOUND From-CUCM
session protocol sipv2
incoming called-number 7T
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0/0
voice-class sip bind media source-interface GigabitEthernet0/0/0
dtmf-relay rtp-nte sip-kpml sip-notify
no vad
dial-peer voice 101 voip
incoming called-number [2-9]..[2-9]......$
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description OUTBOUND to-CUCM-SUB
preference 1
destination-pattern [2-9]..[2-9]......$
session target ipv4:x.x.x.x.
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
description OUTBOUND to-CUCM-PUB
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 300 voip
description OUTBOUND to-ATT
translation-profile outgoing OUTGOING-WAN
preference 1
destination-pattern 7T
session server-group 111
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 301 voip
description INBOUND from-ATT
preference 2
incoming called-number 650.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry register 10
05-22-2017 11:51 AM
Dear Christopher Scopa ,
Most of the time one way audio issue is due to routing issue.Check endpoint to endpoint network routing is there between site.
As call is connected Call manager is out of picture so check your endpoint network have routing to destination endpoint.
05-22-2017 04:09 PM
run a debug ccsip messages and capture the output, I would be particularly interested to see between what IP addresses it is trying to set up the RTP streams
Please rate if useful
05-23-2017 12:02 AM
Sounds like a routing/firewall issue indeed. You can use the following commands to see the audio paths active calls are using:
- show call active voice compact
- show voip rtp connections
- show call active voice | i Peer|Coder|Remote
05-23-2017 01:00 AM
Christopher, ( glad you finally posted here, I couldnt help on the document section as that was not the appropriate forum)
In addition to what everyone has suggested. Try this action plan ( again repeating what others have suggested)
1. run a "debug ccsip message" ( you can attach the logs here)--include calling and called number
The key here is to see where rtp is sent to and to ensure that your IP phone subnets can route to these ip addresses
2. sh call active voice compact ---while the call is connected
3. sh voip rtp connection--while the call is connected
