ā08-14-2023 10:29 AM
What does this number 'Enhanced licenses quantity' refer to in the CCW when ordering a CUBE license outlined in the
What number should I order?
ā08-14-2023 02:53 PM
Each concurrent call consumes a trunk license. Enhanced is only needed instead of Standard if you need box-to-box HA and/or WebSockets for contact center AI functionality.
ā08-14-2023 11:38 PM
@Jonathan Schulenberg You mean I have purchased 40 concurrent calls? If I have two routers for HA, should I purchase 80 licenses or these 40 will be enough? Also, how to know the maximum concurrent call can the router bears?
Thank you so much.
ā08-15-2023 01:28 AM
Youāll need 40 enhanced for 40 concurrent calls. For your other question, that can be found in the data blade for the router.
