Other IP telephony
jankamal6096
 A problem facing while configuring telephony-service on 3750 switch.
When I enable and also put configure terminal and put Telephony-service command and hit enter then it give me error that "  invalid command" what's the problem.please any one explain it.
Switches do not have that functionality. You need to use a router to configure CME.
Response Signature
M02@rt37
Hello @jankamal6096,
You need a router and a licence cme-srst.
Find here the compatible platform:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme141spc.html
Best regards
As other peers mentioned, tlephony-service commmands are avilbale only on Router and not on Switches.
Below mentioned is the router models which you can run CME  and the maximum phone supported.  Also you need licenses
And the Licensing required will be A-FLEX-EP-CME
Response Signature
