calling conference now from 7821 not working
hi
i have an issue with conference now CUCM 12.5
if i call from 7821 call immediately disconnected from other models it works ok (6921 for example
6 Replies 6
Conference Now Number must be reachable irrespective of the phone model. Check the Calling Search Space of the 7821 phone from which you  are calling Conference Now Number.
Response Signature
hi
thank you for reply
the css is configured ok the type of phone is deferent 6921 is working
When you calling conference now number are you getting the IVR ?
What you exactly mean by not working. Is it the IVR not playing or you are not able to login to your meeting number ?
Response Signature
Please check the phone configuration to ensure that it is enabled for Conference Now. If the phone is not configured correctly, Conference Now will not work. For more details on configuring Conference Now, please see the following link: https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/211544-How-to-Configure-Conference-Now-Feature.html
Additionally, as mentioned by @Nithin Eluvathingal, the phone's CSS must be reachable to the Conference Now partition.
hi
phone configuration is fine we might be hitting a bug
Do you receive a fast busy tone or an error message?
Also please post the sdl trace to see if we find something there.
Please let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
