Outbound call -busy tone
Toss Leey
I have following call flow: CUCM-----H323-----CME---FXO, when initiate call give me busy tone, any help plz..
Thank you
Can you please post the show run from GW? Its seems issue to be with TECLO where we are getting power denial event.
As call hitting the GW and matching incoming and outgoing dial-peer , when call traverse over the fXO port its power denial.
In order to test the FXO port or teclo issue, can you please connect analog phone to that port and make test call.
Jun 29 12:17:17.486: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jun 29 12:17:17.486: htsp_timer2 - 1000 msec
Jun 29 12:17:17.486: htsp_timer_stop
Jun 29 12:17:18.486: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Br,
Nadeem
Br, Nadeem Please rate all useful post.
7 Replies 7
Shawn Guertin
Look in your CUCM ig there is an IP in your gateway's page, if not, Its not registered, the registration status does not tell you the truth, the IP does.
If there is no IP address reset/restart the gateway in the CUCM.
There is IP For G.W in CUCM-Gateway Page
Hi Manish
cucm 9.1.1.20000-5
phone: 7942
busy tone after dial No.
I can see FXO 0/0/1 move to Up/OffHook for sec and back to dorm:onhook in CME
+Check Debug/Logs in attachment maybe will be helpful..
The error in the debugs is similar to the following post
https://supportforums.cisco.com/discussion/11353441/srst881-fxo-port-uk-phone-keeps-disconnecting-during-ringing
Try the suggestion as per the post and let us know how it goes.
Manish
Br,
Nadeem
Manish Gogna
Hi Faziz,
Please provide some more details.
CUCM version, phone model being used, when do you get fast busy ( after going off hook or after the called party responds ? etc?
Which codec is being configured between ip phone and h323 gateway and also on CME dial-peers? if the two calls legs are using diff codecs then is there a  transcoder configured?
Manish
Nadeem Ahmed
What is the DNA result shows?Is the call hitting the GW?
Can you please debug the GW atleast see whether call hitting the GW if not then we can troubleshoot on the first node.
Debug voice ccapin inout
debug h225 asn1
debug h245 asn1
debug vpm signal
debug vtsp all
Br,
nadeem
