01-08-2020 12:50 AM - edited 01-08-2020 12:51 AM
Hi - hoping someone can help.
I have inherited a call manager system and an MGCP gateway that has a PRI connected to it. There have been no configuration changes to the call manager or the MGCP gateway but outbound calling has stopped without any reason.
Running debug isdn q931 shows successful incoming calls but nothing displayed for outgoing calls. Phones trying to call outbound just get a busy tone and cannot make a call and the call isn't shown on the MGCP gateway.
Have ran a isdn test call and get the same output as below if I use a leading 9 or not.
isdn test call interface serial 0/0/0:15 08081639549
Jan 8 08:31:21.679: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x0085 callID = 0x8006 switch = primary-net5 interface = User
Jan 8 08:31:21.679: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0085
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98394
Exclusive, Channel 20
Called Party Number i = 0x81, '08081639549'
Plan:ISDN, Type:Unknown
Jan 8 08:31:21.839: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8085
Jan 8 08:31:21.843: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0085
Cause i = 0x80D1 - Invalid call reference value
Jan 8 08:31:25.679: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0085
Standard = CCITT
Jan 8 08:31:25.823: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8085
Jan 8 08:31:25.827: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0085
Jan 8 08:31:29.679: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0085
Cause i = 0x80E6 - Recovery on timer expiry
Jan 8 08:31:29.679: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
01-08-2020 05:35 AM
Have you tried debug mgcp?
What does Dialed Number Analyzer show, perhaps something was changed on CUCM and routing is incorrect to the GW?
With that being said MGCP is notorious for misbehaving and lots of times simple GW reboot or "no mgcp/mgcp" resolves "unknown" issues, have you tried either?
01-09-2020 01:33 AM
Looks like the provider issue was not the problem. I am going to reboot the gateway.
Can I also please check, is the command simply; no mgcp then right afterwards mgcp?
01-08-2020 06:28 AM
Your test call probably didn't work because it was trying to be a video call
add "bearer-cap speech" under your voice port and try again, that on top of what Chris has already mentioned. If the call is not showing on GW debugs, it's not even making it out of CUCM.
01-09-2020 01:34 AM
I'm assuming that would be under this section?
voice-port 0/0/0:15
cptone GB
Thanks!
01-09-2020 03:04 AM - edited 01-09-2020 03:04 AM
Added bearer-cap speech but unfortunately did not resolve issue.
voice-port 0/0/0:15
cptone GB
bearer-cap Speech
Thanks in advance for any more support.
01-08-2020 09:46 AM
Thanks for your suggestions. I had reported this to our provider as a secondary as the calls just randomly stopped. I was about to restart the gateway until the provider found a fault at the exchange. They cleared the error and an outbound call showed correctly, but then the error returned. They're continuing to see a line fault, however should their fix not resolve the issues my next step tomorrow will be to carry out your suggestions. Thank you for the responses, it's appreciated!
01-09-2020 02:31 AM
01-09-2020 03:59 AM
And another update. One of the buildings on-site can make calls outbound no problem and they hit the gateway, but any other building on-site can't make outbound calls - they don't hit the gateway.
I have set myself up with a test registering to the same call manager with the exact same settings as a known working person in one of the building that can make an outbound but mine fail with the same issue of the busy tone and nothing appearing on the gateway.
01-09-2020 05:51 AM
Couple of things to check if you eliminated routing issues (confirmed above with DNA), make sure Call Admission Control is not blocking the calls (Location and links configuration), but your best option at this time would be to pull CUCM SDL traces and review them for reasons of the failure.
