Outbound calls not working
Leonardo Santana
We have a E1 R2 and outbound calls are not being established. Inbound calls are ok.
ios:c2951-universalk9-mz.SPA.152-4.M7.bin
Call Flow: IP Phone -> CUCM -> SIP TRUNK -> Voice Gateway -> E1 R2-> TELCO
The debug vpm signal is attached.
What could be the issue?
I have already tested this E1 R2 link in two differents routers.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
9 Replies 9
Dennis Mink
Leonardo,
looking at your debug it seems as if you are dialing "#2#2#1#......" ending with a * ,after this the disconnect takes place, as if options on an IVR are being keyed in.  where does that come from?
Please remember to rate useful posts, by clicking on the stars below.
Hi  Dennis,
I agree with you, this is strange.
The number dialed was 2217-8631 from extension 3784
E_HTSP_SETUP_REQ DNIS=22178631 ANI=3784
Jan 19 00:18:07.900: r2_reg_generate_digits(0/0/0:0(1)): Tx digit '3'
Jan 19 00:18:08.000: htsp_digit_ready_up(0/0/0:0(1)): Rx digit='1'
Jan 19 00:18:08.000: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:0): STATE: R2_OUT_PROCESS_A R2 Got Event 1
Jan 19 00:18:08.000: r2_reg_generate_digits(0/0/0:0(1)): Tx digit '#'
Jan 19 00:18:08.120: htsp_digit_ready(0/0/0:0(1)): Rx digit='#'
Jan 19 00:18:08.120: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:0): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
Jan 19 00:18:08.120: r2_reg_generate_digits(0/0/0:0(1)): Tx digit '1'
Jan 19 00:18:08.220: htsp_digit_ready_up(0/0/0:0(1)): Rx digit='1'
Jan 19 00:18:08.220: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:0): STATE: R2_OUT_PROCESS_A R2 Got Event 1
Jan 19 00:18:08.220: r2_reg_generate_digits(0/0/0:0(1)): Tx digit '#'
Jan 19 00:18:08.340: htsp_digit_ready(0/0/0:0(1)): Rx digit='#'
Jan 19 00:18:08.340: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:0): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
Jan 19 00:18:08.340: r2_reg_generate_digits(0/0/0:0(1)): Tx digit '*'
Jan 19 00:18:08.448: htsp_process_event: [0/0/0:0(1), R2_Q421_OG_SEIZE_ACK, E_DSP_SIG_1000]
Jan 19 00:18:08.448: r2_q421_seize_to(0/0/0:0(1)) Tx CLEAR FWDvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:0(1)] set signal state = 0x8
Jan 19 00:18:08.448: htsp_timer - 1000 msec
Jan 19 00:18:08.448: r2_reg_channel_disconnected(0/0/0:0(1))
Daniel Sobrinho
dsobrinho
Level 9
Level 9
Hi Leonardo,
Check the link below. The problem description is the same.The PSTN had configured the circuit as unidirectional configuration.
Like this:
1-15 - incoming calls
17-31 - outgoing calls
https://supportforums.cisco.com/discussion/12178771/outgoing-calls-e1-r2-digital-dont-work
Best regards,
Daniel
Daniel Sobrinho
Hi Leandro,
This might be a bidirectional trunk not setup from the carrier as Daniel's suggestion. I believe as the digits are actually after the Wink being received with acknowledgment  of each digits suggests it might be an outgoing trunk but to double check. However the final "*" is a weird item as well as after that the Caller ID should be sent after the DNIS. Could you post the  cas custom configuration, IOS Version, and also deb vtsp all
Best Regards
Moniem
Hello all,
We change for ISDN and it works.
Leonardo Santana
Leonardo Santana
Hi Leonardo,
I am glad know that problem was resolved with this move.
Have nice day
Daniel Sobrinho
Daniel Sobrinho
Hello Leandro,
I believe if you get the chance to go for a Digital ISDN PRI alternative option to E1 R2 it is always a better controllable and globally standaridised option. Great that your business is restored.
For my curiosity, would it be possible to know the cas-custom options you configured prior. If not, I am glad that everything is ok
Best Regards,
MonieM
Hello Abdel,
This was the E1 R2 config before the change:
controller E1 0/0/0
 framing NO-CRC4
 line-termination 75-ohm
 ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
 cas-custom 0
  country brazil
  metering
  debounce-time 10
  answer-signal group-b 1
  dnis-digits min 1 max 4
  dnis-complete
This is the new ISDN PRI config that itis working:
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn incoming-voice voice
 no cdp enable
Leonardo Santana
Leonardo Santana
Dear Leandro
Thanks for posting the Configuration.
I am not sure, but I think the default configuration for Brazil was going to make a difference here as most of the carriers accesspt Category 2 and I dont think they need dnis-complete (or metering option) (I think this is the "*" at the end but not sure).
My suggestion was going to be having the following:
controller E1 0/0/0
framing NO-CRC4
cas-custom 0
  country brazil use-default
  category 2
However, I believe the ISDN PRI still a better option and easy to manage.
Thanks and Best regards
MonieM
