Outbound calls over PRI aren't working. "Cause No. 44 - requested circuit/channel not available."
tylerlucas
Configured a 2650XM for outbound calling over a PRI.  This router has been used for voice before.
Created a dialpeer for a SIP trunk to a Mitel call control server.  Also created a dialpeer for the analog PRI trunk.
When a call is placed outbound, it hits the Mitel, then is sent to the router.  I see this happening in logs, and the correct dialpeers are selected.  When the router attempts to send the call to the PRI, though, I get the following error:
*May  1 03:44:29.247: //19/355048E1801E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8441D278, Tag=0x0, Call Id=19,
   Call Entry(Disconnect Cause=44, Voice Class Cause Code=0, Retry Count=0)
I called the provider and verified that the circuit is functional.  They said it is, but I'm still not 100% sure.
I'm fairly new to telephony config, so its very possible I am forgetting some very obvious step.  Config below:
Building configuration...
Current configuration : 2079 bytes
version 12.4
hostname 2600-PRI-GTY
boot-start-marker
boot-end-marker
logging buffered 999999 debugging
no logging console
no logging monitor
XXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa session-id common
network-clock-participate wic 0
network-clock-select 1 T1 0/0
voice-card 0
dspfarm
no local-bypass
ip cef
no ip domain lookup
ip domain name XXX
isdn switch-type primary-ni
voice call carrier capacity active
voice service voip
voice translation-rule 1
rule 1 /116057154920/ /16057154920/
voice translation-profile XLATE
translate called 1
XXXXXXXXXXXX
controller T1 0/0
framing esf
fdl both
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface FastEthernet0/0
ip address 10.250.0.10 255.255.255.0
duplex auto
speed auto
interface Serial0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.250.0.1
no ip http server
control-plane
voice-port 0/0:23
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
dial-peer cor custom
dial-peer voice 98 voip
description FROM MITEL
signaling forward unconditional
session protocol sipv2
session target sip-server
session transport tcp
incoming called-number .
dtmf-relay sip-notify rtp-nte
no vad
dial-peer voice 99 pots
translation-profile outgoing XLATE
destination-pattern .T
direct-inward-dial
port 0/0:23
forward-digits all
sip-ua
sip-server ipv4:10.0.2.16
line con 0
line aux 0
line vty 0 4
privilege level 15
logging synchronous
transport input telnet
end
As a side note: This was configured to use a Cisco Call Manager previously - maybe there is some residual config messing me up?
2 Accepted Solutions
bmcghee
you need to remove the "service mgcp"
You have the T1 bound to MGCP, but MGCP not running. That could be confusing things.
Assuming CCM is dead and gone, do this:
Conf t
Voice-port 0/0:23
shut
Int ser 0/0:23
Shut
Controller e1 0/0
Shut
No pri-group timeslots 1-24 service mgcp Pri-group timeslots 1-24 No shut
Then reapply the port to the dial-peer, usually it's deleted by the above actions..
Dial-peer voice 99 pots
Port 0/0:23
Check the status of the circuit:
Sh controllers t1
Show isdn status
Also, you sometimes see that channel/circuit error if the trunk is up, but all the B channels are unavailable (i.e. SP has them disabled). If you still have problems after the above, you may need to go back to them.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
tylerlucas
2600-PRI-GTY#sh int s0/0:23
Serial0/0:23 is up, line protocol is up
  Hardware is DSX1
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Last input 00:00:01, output never, output hang never
  Last clearing of "show interface" counters 2d18h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     10624 packets input, 31872 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
2600-PRI-GTY#sh controller t1
T1 0/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is ESF, FDL is ansi & att, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (883 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
2600-PRI-GTY#
Conf t
Voice-port 0/0:23
shut
Int ser 0/0:23
Shut
Controller e1 0/0
Shut
Port 0/0:23
Sh controllers t1
Show isdn status
Aaron
bmcghee
