Outbound H323 Fax busy signal
AresWare
Hi all thanks in advance,
First of all, I'm really new to cisco. But I'm depreciating our old fax server that uses perle modem cards. I'm using t38modem software. I have a h323 endpoint setup on CUCM that has no problem receiving calls and faxes however when trying outbound it gets a busy tone. Any ideas?
Are you able to make outgoing calls from the H.323 end point ? If yes and only fax failing, i assume you send fax to ISP with protocol which they are not compatible.
Are you sure that the ISP use t38 for FAX ?
Secondly what is this h.323 device, is it VG or a gateway ? Can you explain a little more about your setup  ?
Response Signature
I appreciate your reply I haven't tested h323 as a phone cause this is purely a software-based setup. But I am going to try later today. This isn't a VG or a gateway, it's acting as a phone as CUCM marked it. In our environment, we do have h323 gateways and a VG310 (for the analog translation to the physical fax machines and cards). Let me know if this makes sense thanks!
