what is Enterprise Feature Access
Ahmed Tarek
Level 3
Level 3
2 Accepted Solutions
Jonathan Schulenberg
Two-stage dialing initiated from the Jabber/Webex apps requires Dial via Office-Reverse (note: this is also disabled by default on the TCT/BOT device). Two-stage dialing from a PSTN origin (eg hotel phone for international toll bypass) requires that you also setup Mobile Voice Access: user calls the MVA pilot, authenticates, and can then originate an outbound call from their enterprise DN.
Mid-call features are just the ability to invoke hold/transfer/park/etc using DTMF star codes, similar to how an SCCP-controlled FXS port would.
Enterprise Feature Access is when you use Mobile Voice Access and make the call from a configured Remote Destination. With the advent of Mobile Remote Access on Expressways the use case for both MVA and EFA are not really that applicable anymore as you can get a much more seamless UX by using Webex or Jabber on the mobile device and making the call from these applications. What is it that you’re trying to accomplish from a user experience perspective? If you describe that we might be able to provide you with some options.
Response Signature
Response Signature
i just get a little confused for this feature, duo to i have jabber so why i need to use MVA and EFA ? , so  i asked for it
Simple answer, you don’t.
Response Signature
