Outgoing Call through MGCP is not working
Driss BENATTOU
Level 4
Level 4
I have a CUCM 9.1.1 and Cisco 3925 VGW. I configured 3 E1 using MGCP. When I did an outgoing call, the call is going through the second E1 port into the route Group. I suspected an issue on Telco side. When I configured H323, the first E1 port into the route group which is IP address of Voice Gateway is reached and the call went through the right TELCO.
Below; the Debug isdn q931 when using MGCP :
VG2MGCP-NU#
*Sep 23 17:10:38.355: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x000D
    Sending Complete
    Bearer Capability i = 0x8090A2
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98381
        Exclusive, Channel 1
    Calling Party Number i = 0x0081, '1930'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '0664727989'
*Sep 23 17:10:38.411: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x800D
    Cause i = 0x829F - Normal, unspecified
Also, You will find the prompt of show run command :
Current configuration : 12029 bytes
! Last configuration change at 16:58:09 UTC Tue Sep 23 2014
version 15.2
hostname VG2MGCP-NU
boot-start-marker
boot-end-marker
card type e1 0 0
! card type command needed for slot/vwic-slot 0/1
card type e1 0 2
logging buffered 51200 warnings
enable secret 4 X4ZqtPJ///KxuEWxHSsJrv3beQVnz2ise/xj8fF6eFU
no aaa new-model
no network-clock-participate slot 1
network-clock-participate wic 0
network-clock-participate wic 2
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
trunk group GSM_INTL_CALLS
 max-calls voice 40
 hunt-scheme round-robin
voice-card 0
voice-card 1
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
 callmonitor
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  call preserve
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
 rule 1 /^3\(...\)/ /3\1/
 rule 2 /^1.../ /\0/
voice translation-rule 2
 rule 1 /^890\(....\)/ /\1/
 rule 2 /^8903\(...\)/ /3\1/
voice translation-rule 3
voice translation-rule 4
 rule 1 /^1.../ /\0/
voice translation-rule 5
 rule 1 /0661087907/ /\1/
voice translation-profile 7to4
 translate called 3
voice translation-profile From-PABX
 translate calling 2
voice translation-profile FromIAM
 translate called 4
voice translation-profile Incoming
 translate called 1
voice translation-profile TESTINCOM
 translate called 5
license udi pid C3900-SPE100/K9 sn FOC17442CB6
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
redundancy
controller E1 0/0/0
 pri-group timeslots 1-31 service mgcp
 description "CONNECTED TO MEDITEL"
controller E1 0/0/1
controller E1 0/0/2
 description "CONNECTED TO IAM"
controller E1 0/0/3
controller E1 0/2/0
 framing NO-CRC4
 description "CONNECTED TO INTERCO"
controller E1 0/2/1
 framing NO-CRC4
controller E1 0/2/2
 framing NO-CRC4
controller E1 0/2/3
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 22.74.251.18 255.255.255.240
 duplex auto
 speed auto
 h323-gateway voip interface
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 no cdp enable
interface Serial0/0/1:15
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/0/2:15
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/0/3:15
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/2/0:15
 no ip address
 encapsulation hdlc
 no logging event link-status
 isdn switch-type primary-qsig
 isdn timer T310 120000
 isdn overlap-receiving T302 2000
 isdn protocol-emulate network
 isdn negotiate-bchan
 isdn sending-complete
 no cdp enable
interface Serial0/2/1:15
 no ip address
 encapsulation hdlc
 isdn supp-service name calling profile Network-Extension operation-value-tag local
 no cdp enable
interface Serial0/2/2:15
 no ip address
 encapsulation hdlc
 no cdp enable
interface BRI1/0/0
 no ip address
 isdn switch-type basic-net3
 isdn point-to-point-setup
interface BRI1/0/1
 no ip address
interface BRI1/1/0
 no ip address
interface BRI1/1/1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 22.74.251.30
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0:15
voice-port 0/2/0:15
 translation-profile incoming Incoming
 bearer-cap Speech
voice-port 0/0/1:15
voice-port 0/2/1:15
 bearer-cap Speech
voice-port 0/0/2:15
voice-port 0/2/2:15
 bearer-cap Speech
voice-port 0/3/0
 trunk-group GSM_INTL_CALLS
 supervisory disconnect dualtone mid-call
 cptone FR
 timeouts call-disconnect 5
 timeouts ringing 5
 timeouts wait-release 5
 timing hookflash-out 50
 timing guard-out 1000
 impedance complex2
voice-port 0/3/1
 cptone FR
 timeouts ringing 5
 impedance complex2
voice-port 0/3/2
 cptone FR
 timeouts ringing 5
 impedance complex2
voice-port 0/3/3
 cptone FR
 timeouts ringing 5
 impedance complex2
voice-port 0/0/3:15
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
ccm-manager redundant-host 22.74.251.1
ccm-manager mgcp
ccm-manager config server 22.74.251.2 22.74.252.1
mgcp
mgcp call-agent 22.74.251.2 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
dial-peer voice 999010 pots
 service mgcpapp
 port 0/3/0
dial-peer voice 999011 pots
 service mgcpapp
 port 0/3/1
dial-peer voice 999012 pots
 service mgcpapp
 port 0/3/2
dial-peer voice 999013 pots
 service mgcpapp
 port 0/3/3
dial-peer voice 3 voip
 tone ringback alert-no-PI
 destination-pattern 3...$
 session target ipv4:22.74.252.1
 voice-class codec 1
 no vad
dial-peer voice 5 voip
 translation-profile outgoing 7to4
 destination-pattern 1...$
 session target ipv4:22.74.251.2
 incoming called-number .
 voice-class codec 1
 no vad
dial-peer voice 6 voip
 preference 1
 voice-class codec 1
 no vad
dial-peer voice 4 voip
 preference 1
dial-peer voice 1 voip
 shutdown
 destination-pattern .T
 voice-class codec 1
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 2 voip
 preference 1
 shutdown
 no vad
dial-peer voice 7 voip
 shutdown
 voice-class codec 1
dial-peer voice 8 pots
 shutdown
 port 0/2/0:15
 forward-digits all
dial-peer voice 9 pots
 preference 1
 shutdown
 port 0/2/1:15
 forward-digits all
dial-peer voice 10 pots
 preference 2
 shutdown
 port 0/2/2:15
 forward-digits all
dial-peer voice 11 pots
 destination-pattern 7T
 port 0/2/0:15
 forward-digits all
dial-peer voice 12 pots
 preference 1
 port 0/2/1:15
 forward-digits all
dial-peer voice 13 pots
 preference 2
 port 0/2/2:15
 forward-digits all
dial-peer voice 14 voip
 shutdown
 destination-pattern 1616
 voice-class codec 1
 no vad
dial-peer voice 15 voip
 shutdown
dial-peer voice 100 pots
 destination-pattern 0T
 direct-inward-dial
 port 0/0/2:15
 forward-digits all
dial-peer voice 101 pots
 preference 1
 direct-inward-dial
 port 0/0/3:15
 forward-digits all
dial-peer voice 1643 pots
 destination-pattern 1643$
 port 0/2/0:15
 forward-digits all
dial-peer voice 9999 voip
 voice-class codec 1
dial-peer voice 555 pots
 destination-pattern 5T
 direct-inward-dial
 port 0/2/2:15
gateway
 timer receive-rtp 1200
gatekeeper
 shutdown
Any Ideas Please ?
Ayodeji Okanlawon
From the logs, it shows that the telco is sending the disconnect. Have you spoken to them?
Please rate all useful posts
The same port works when the protocol is H.323 instead of MGCP.
I  understand that but the Telco is still disconnecting the call. You will need to compare the logs between the h323 and mgcp to see the difference in what you are sending to your telco
Good info Ayodeji (+5)
I would also ask the carrier what TON, they expect.
Yosh
HTH Regards, Yosh
