Paging Issue on CME
Mohamed Haneefa
Dear Experts....
                                    After long time ,I use to created a paging service on my client in CME as follows.....
ephone-dn 86
name Paging
number 1234
paging ip 239.1.1.10 port 2000
ephone 1
mac-address 8478.ACC6.958A
button 1:1
paging-dn 86 unicast
ephone 2
mac-address 5475.D02A.F36E
button 1:2
ephone 3
mac-address 8478.ACC6.997E
button 1:3
My problem is simple,when i use to dial on page number as 1234 ,its working with all connected page-dn's,After disconnect from page service  some of telephones(6921) are not getting the dial tone ,even can't call internally or simply say phone get hang.does any one face this issue so far.please check my check above config & let me know your suggestion here!!!!
!!!!!!!!!!& one more thing ,as my client using both sip & sccp types. is there any extra configuration needed for paging for communicating between SIP & SCCP?..
2 Accepted Solutions
As i can see the ip phones and the cme in different subnets
What is your default gateway here?
Core Switch maybe
If so, configure multicast routing between vlans to route the paging packets
Under both vlan interfaces in the core switch add this command:
ip pim sparse-dense-mode
also add this command in the configuration mode:
ip multicast-routing
6 Replies 6
Laith Ibrahim
why are you using unicast here?
the paging-dn command should use multicast,
did you try it?
Dear laith
                    let me tell you first of all,I did configured as multicast (paging-dn 86 multicast).it wont work.then i use to configure as uni-cast,it woks only up to 10 SCCP phone at a time.I have never been configure for multicast address in CME. could you show me how to configure it.below find the CME and IP phone informations as follows !!!!
CME        10.11.7.2
Subnet     255.255.255.0
IP Phone 10.11.8.x
Core Switch maybe
Dear Laith
Thank you for your information. please find my network  as follows !!!!
CME          10.11.7.2
IP Phone  10.11.8.x
Default gateway 10.11.8.1
yes  DGW is core switch...
 do you have any template to create a multicast for paging between CME and core switch?
you can use my above network information to create a sample config. !!!!.
coultera
I know it's been a long time. But, if anyone is in a situation where the device (core switch) is not Cisco and doesn't support IGMP, or is not compatible with Cisco IGMP, you can get the above CME paging configuration to work with unicast if you change the port to 20480. Per this document:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmepage.html#task_CEB06C2C65A54FE0A27DFD622163F00B
"If any of the paged phones is a Cisco Unified SIP IP phone, the correct paging port for the paging-dn is an even number from 20480 to 32768. If you enter a wrong port number, a SIP REFER message request is sent to the IP phone but the Cisco Unified SIP IP phone is not paged."
