Paging over IP Phones (CUCM)
Does anybody know if it is possible to activate paging over IP Phones ???, It means, to off hook and dial any code in order to make paging over some phones that belong to a kind of paging group.
Thanks in advance.
3 Accepted Solutions
Jaime Valencia
CUCM doesn't have paging, this requires a 3rd party app.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
barry
Level 7
Level 7
As java says, unlike CME, CUCM doesn't support native paging.
Couple of options:
Berbee Informacast  (although I haven't tried this since Berbee got bought by CDW)
Syn-Apps
HFH. Barry
I just got done with a demo for this exact thing with Syn Apps' SA-Announce product. It was super easy to set the server up and worked like a champ, we are going to buy it. Just go to their website and fill out some info and they will send you a key for a 30 day demo. There are other neat features along with it too so it does more than just paging. Its also cheap believe it or not.
6 Replies 6
Jaime Valencia
java
java
Thanks for your support.
barry
Level 7
Level 7
Couple of options:
Syn-Apps
HFH. Barry
Folks that made InformaCast at Berbee are on their own now. Company is called SingleWire.
You can use a third party application
http://www.connectps.com/xml.htm
Mohamed
