PAI from inc 180 not the same as out 183
Paul Freiberg
Hi all,
I'd like to got the same PAI Header in the outgoing 183 like in the corresponding incomming 180.
Inc 180:
SIP/2.0 180 Ringing
Via: SIP/2.0/TCP x.x.x.x:5060;branch=z9hG4bK3F301614
From: "Paul Freiberg" <sip:+4945131012012@x.x.x.x>;tag=8951FBF8-2204
To: <sip:+49xyz@x.x.x.x>;tag=1397049727
Call-ID: 3C32A106-118611E8-B242F8A7-FD090289@x.x.x.x
CSeq: 101 INVITE
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, REFER, INFO, PRACK, UPDATE
Contact: <sip:+49xyz@x.x.x.x:5060;transport=tcp>
P-Asserted-Identity: "FREIBERG PAUL" <sip:+49xyz@x.x.x.x>
Require: 100rel
RSeq: 1
Server: xxx
Content-Type: application/sdp
Content-Length: 245
--SDP--
Out:
SIP/2.0 183 Session Progress
Via: SIP/2.0/TLS x.x.x.x:5061;branch=z9hG4bK5359b5fe5d873
From: "Paul Freiberg" <sip:+4945131012012@x.x.x.x>;tag=7347937~4498ec3c-29e8-4cb2-abe3-b65eefebc6a9-49458581
To: <sip:+49xyz@x.x.x.x>;tag=8951FFC0-655
Date: Thu, 15 Feb 2018 12:54:46 GMT
Call-ID: 64e9b480-a8518316-41f65-650116ac@x.x.x.x
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
P-Asserted-Identity: <sip:+49xyz@x.x.x.x>
Contact: <sip:+49xyz@x.x.x.x:5061;transport=tls>
Supported: sdp-anat
Server: xxx
Content-Disposition: session;handling=required
Content-Length: 327
--SDP--
How can I copy that PAI information? Copy List seems to work just for incomming messages on incomming dial-peers?!
Paul
R0g22
SIP Copy list should work just fine.
1. Create a copylist and mention the header from the incoming message that needs to be picked up i.e. PAI in your case.
2. You apply this copylist to the incoming dial-peer
3. Next you create a SIP profile to grab the copied header stored in a variable which would be "u01". Something like -
voice class sip-profiles <number>
response 183 peer-header sip P-Asserted-Identity copy "<sip:(.*)@" u01
4. Apply this SIP profile to the outgoing dial-peer
You can use the following debugs to see this in action as well-
debug voice ccapi inout
debug ccsip messages
debug ccsip info
debug ccsip feature sip-profile
Unfortunately it did not helped me.
My u2 is always empty.
If I want to copy information of an incoming request to use it on outgoing call leg it works fine.
But if I do like you wrote I see no action before the 183 response is sent.
If I set the sip-profile to the incomming dial-peer there is just an empty u2 variable before 183 is sent.
I also tried to set the copy list to the outgoing dial-peer without success.
Paul
Not sure if I am following you.
You need to apply the copy list on the incoming dial-peer and use the peer-header to copy the stored variable from the incoming message to the outgoing message with a sip-profile on the outgoing dial-peer.
Apply the config exactly like I have shown above and send me the "show run" from the CUBE. Also take a log for the debugs that I highlighted with the config in place.
