Parallel hunt groups using sccp + CUCM 9.1
wilsonsant
Level 6
Level 6
Hi Guys,
I would like know if the limitation about CME previously still continue in version 9.1. I did the configuration and didn´t worked. I used the document below as reference
https://supportforums.cisco.com/discussion/10147131/parallel-hunt-groups-using-sccp
Are there documentation Cisco informing about this?
Wilson
Rob Huffman
Hi Wilson,
Here is the reference related to this query;
Parallel Hunt Groups (Call Blast)
In a parallel hunt group, calls simultaneously ring multiple phones. Using parallel hunt groups is also referred to as application-level forking because it enables the forking of a call to multiple destinations. In versions earlier than Cisco Unified CME 4.3, only SIP phones support parallel hunt groups. In Cisco Unified CME 4.3 and later versions, SCCP phones also support voice hunt groups.
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmecover.html#pgfId-1145800
Cheers!
Rob
Hi Rob,
Are there a documentation specific about version 9.1. informing about this limitation or carecteristic.  will have that pass this information for my Customer?
Wilson
Rob Huffman
Hi Wilson,
Unlike CUCM, CME does not have version specific config docs and they are bundled into the Call Coverage feature doc like the one I linked above. The customer would need to look at the feature History Roadmap doc to see when this capability was added (see below)
Cisco Unified CME 7.0/4.3
7.0/4.3
Autoprovisioning Directory Numbers in SRST Fallback Mode
Allows you to specify whether Cisco Unified CME in SRST Fallback mode creates octo-line or dual-line directory numbers for ephone-dns that are “learned” automatically from the ephone configuration.
Configuring SRST Fallback Mode
Barge
Enables phone users to join a call on a shared octo-line directory number by pressing the Cbarge soft key and converting the call to an ad hoc conference.
Configuring Barge and Privacy
Call Transfer Recall
Enables a transferred call to return to the phone that initiated the transfer if the destination does not answer.
Cisco 3200 Series Mobile Access Router
Support for Cisco Unified CME on the Cisco 3200 Series Mobile Access Router was added.
Cisco Unified IP Phones
Adds SCCP support for the following phone types:
  • Cisco Unified IP Phone 7915 Expansion Module
  • Cisco Unified IP Phone 7916 Expansion Module
  • Cisco Unified IP Conference Station 7937
  • Nokia E61
Adds SIP support for the following phone types:
  • Cisco Unified IP Phone 7942G and 7945G
  • Cisco Unified IP Phone 7962G and 7965G
  • Cisco Unified IP Phone 7975G
Cisco Unified Communications Manager Express 7.0/4.3 Supported Firmware, Platforms, Memory, and Voice Products
Consultative Transfer Enhancements
Modifies the digit-collection process for consultative call transfers. After a phone user presses the Transfer soft key for a consultative transfer, a new consultative call leg is created and the Transfer soft key is not displayed again until the dialed digits of the transfer-to number are matched to a transfer pattern and consultative call leg is in alerting state.
Directory Search Enhancement
Increases the number of entries supported in a search results list from 32 to 240 when using the directory search feature.
Configuring Directory Services
Extension Mobility Enhancement
Adds support for the following:
  • Automatic Logout, including:
 Configurable time-of-day timers for automatically logging out all EM users.
 Configurable idle-duration timer for logging out a single user from an idle EM phone.
  • Automatic Clear Call History when a user logs out from EM.
Configuring Extension Mobility
Phone-Type Configuration
Allows you to dynamically add a new phone type to your configuration without upgrading your Cisco IOS software.
Live Record
Enables IP phone users to record a phone conversation when Cisco Unity Express is the voice mail system.
Integrating Voice Mail
Maximum Ephones
Sets the maximum number of SCCP phones that can register to Cisco Unified CME using the max-ephones command, without limiting the number that can be configured. This enhancement also expands the maximum number of phones that can be configured to 1000.
Octo-Line Directory Numbers
Adds octo-line directory numbers that support up to eight active calls, both incoming and outgoing, on a single phone button. Unlike a dual-line directory number, an octo-line directory number can split its channels among other phones that share the directory number.
Privacy
Enables phone users to block other users from seeing call information or barging into a call on a shared octo-line directory number.
Push-to-Talk
Adds support for one-way Push-to-Talk (PTT) in Cisco Unified CME without requiring an external server to support the functionality. PTT is supported in firmware version 1.0.4 and later versions on Cisco Unified wireless IP phones with a thumb button.
SCCP: Configuring One-Way Push-to-Talk on Cisco Unified Wireless IP Phones
Speed Dial/Fast Dial Phone User Interface
Allows IP phone users to configure their own speed-dial and fast-dial settings directly from the phone. Extension Mobility users can add or modify speed-dial settings in their user profile after logging in.
Configuring Speed Dial
Transfer to Voice Mail
Allows a phone user to transfer a call directly to a voice-mail extension by pressing the TrnsfVM soft key.
Voice Hunt-Group Enhancements
Supports the following Voice Hunt Group features:
  • Call Forwarding to a Parallel Voice Hunt-Group (Blast Hunt Group).
  • Call Transfer to a Voice Hunt-Group.
  • Member of Voice Hunt-Group can be a SCCP phone, FXS analog phone, DS0-group, PRI-group, SIP phone, or SIP trunk.
 From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmeroad.html
