IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5852 Views
  • 14 replies
Hi, Here is my scenario.Incoming call SIP Trunk 2811 ==> CUBE 3845 IVR ==> via Dial-peers Towards CM. My IVR is on 3845 PRI router, working fine. Now i also have 2811 router sip trunk. Now i need to forwards SIP calls from 2811 towards 3845 router IV...
Hi All, I got a request to setup CDR feature in CME environment with Custom report format. I did google and find one PDF that says use Radius server to integrate with CME. Please advice as the configuration seems that need to configure aaa with Radiu...
I have two new factory installed B7k servers that appear to be running very slow.They have been preinstalled with the Cisco OEM 5.5 update 2 Esxi which appears to be the latest available. I have updated all bios and firmware using the latest HUU(2.0....
neily by Level 1
  • 681 Views
  • 5 replies
hi everybody, I am new in voice field My company has around 25 users, and they have 2FXO ports in CME, now they want to migrate from CME to CUCM,  so i want to know how to configure FXO ports for CUCM.. please explain this to me
Hi All, Hope someone could possibly help me out here as this is driving me crazy! My CUCME is falling over about every 12 hours. When i do a sh log i get:%IVR-3-LOW_CPU_RESOURCE : IVR: System experiencing high cpu utilization (99/100). Call (callID=8...
Hi All, I'm looking for a procedure on configuring ATA's on the CME. I would like to connect this ATA to a Xerox printer and only use it for faxing capabilities. Does anyone have some good documentation to provide?
techsmrdr by Level 1
  • 186 Views
  • 0 replies
Hello Everybody,I am pretty new in Voice, and my small company wants to move from cme to CUCM,What are the things I should keep in mind?-- They have only two FXO ports for CME, can we configure FXO ports for CUCM? and how?-- What about the licenses?-...
