Partitions and CSS management
ilana_ilana
Hello all,
Is there any tool available where we can manage large number of partitions and css in easy way?
We hav project where customer is going to deploy centralized cucm design for 40+ sites. According to our design each site will have a set of pt & css. We will have around 10 partitions and css for each site. So total we are going to manage 400 pt's and css.
Is there any tool where we can manage PT's & CSS in efficient way ?
Dennis Mink
There is no external tool available to actively manage this.
You can bulk import and export partitions and CSS, through the Bulk administration tool, but there is no dedicated tool that can do this (although technically it can be developed).
Please remember to rate useful posts, by clicking on the stars below.
Manish Gogna
As Dennis said there is no such tool available,  however you can minimize the number of partitions and CSS by developing a good dial plan with minimal overlaps and using Standard Local Route Group for Route patterns so that in some cases a single route pattern ( like 911 for example ) is needed for all sites.
Manish
j.huizinga
Level 6
Level 6
As already mentioned, used local route groups and also create a CSS that allows everything on the device and create CoS on the lines. The CoS can be applied regardless of the remote site
Design this before programming
JH
