PC program that orders IP phone to place a call
wamohamad
Hi Everyone,
In our company we've deployed IP telephony and a phone directory program was made to make the search for contacts more easier from PC not the IP phone
We want to make the user just when selecting a contact from the list on the PC then an order is given to the attached IP phone to dial the selected number
So what should I have?
And is there any configuration needed on the callmanger?
Any help is appreciated
barry
Level 7
Level 7
You haven't specified which phone system you are on, but assuming its CUCM (Communications Manager), click to call is probably the easiest one for you to use. This is supported in CUCM 7.0 and higher, although I have tested on 6.1(3) and it also seems to work.
http://www.cisco.com/en/US/partner/products/ps9829/index.html
Barry
5 Replies 5
barry
Level 7
Level 7
Barry
Hi dears....
You can use.....Cisco web dialer from PC tp make call, Web dialer is already in your CUCM be default.
or
you can additionally use cisco click to call applicaion.
Click to call Orders a wide range of application s to make call from PC,like below shown
Mozilla Firefox 1.5 & 2.0
Internet Explorer 6.0 & 7.0
Microsoft Outlook 2003 & 2007
Microsoft SharePoint 2003 & 2007
Microsoft Office:
Word 2003 & 2007
Excel 2003 & 2007
PowerPoint 2003
Good Day.
Many thanks, Barry
I've got click to call and it workded very well
Thank you
Jaime Valencia
Look at the click to call widget.
Cisco Unified Communications Widgets
More info available on CCO if you search click to call.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Java,
You have any documnets with Cisco Click to call plz share.......
I have already downloaded and installed not yet used complety......
From my theoratical knoledge only i put the comments previously....
Good day_  Bro
