Hello All , can we change callmanager admin password and username , as our auditor requested to change this username and password . we have three nodes in the cluster . any risk involed in it .regards , Aslam
Can you connect ATA187(SIP9 to a CUCMExpress ?Thanks to all
Hi All,I am facing problem with FAX line. When I am dialing fax number, it rings and after 4 rings I get fast busy singnal.Can someone tell me why I am getting fast busy signal instead of fax tone ?Thanks
Hi,This is for a call center where about 200 concurrent callers from PSTN leave messages in a voicemail box. Agents listen to the messages and call back. Or a software can be written to read the caller-id and deliver caller-id to agents.Are there any...
Hi AllI have a remote site that ring the central site using G729. However the central site phone is configured to CFB and CFNoan to voicemail which is Unity Connection. The remote site get a fast busy. I thought Unity Connection can negotiate and ...
Hello,I have some problems with AAA configuration on C3945E box.Cisco is configured to handle sip calls from X.X.X.X and direct them to Y.Y.Y.Y.Additionally i have radius server which is acting as a AAA node. All calls passing through Cisco should be...
I have 4 CUCM 6.1 servers (1 Publisher and 3 subscribers). Right now my call manager group as 1 PUB and 2 SUBs in it since I can only add 3 call manager servers to a group. How can I use that 3rd subscriber? It's at a remote site and was purchased...
Hello,We have a customer who have a MGCP gateway contains 3 VIC2-4FXO + E1 pri, the mgcp gateway and its voice cards are registered with cucmbe. the mgcp gateway is directly through E1 PRI to a CME. And E1 card is registred with CUCMBE and there is ...
HI,i can not dream without bringing back to life my cisco 7911. His twin (other 7911) had been died too but with the DHCP, tftp servers and Factory reset 123456789*0# and 3491672850*# it worked and the firmware was restored but this phone is too dead...
Hi,As the ATA186 is EOS since sept. 30th and the ATA187 will not work with CME before july 2011 what is a workaround for Cisco ?Any way to implement an analogue phone where customers are expecting a solution with ATA as they already have?I expect tha...
Hi, I have been working on an intermitent DTMF problem for some days for one of our sites. I read about some set up that deny it working right away but this site has two gateways deployed for 6 months already and people started complaining about it l...
Does anyone know of an acceptable delay (network ms/round trip) to move away from CUE to a central voicemail solution?
I would like to configure the 7962 at my desk to look like a 7962 at another location. I have added BLF speed dials and I want to make sure they are working from my phone without disturbing the other line how do I go about this? I want my phone to b...
Hi,About to integrate CUCM 7.1 and Unity connection 7.1 with LDAP / AD.The userids in AD and Cisco don't match. Changing the AD Userids is out of the question for obvious reasons.So before starting the LDAP process I would like to change all userids...
Hi,I have ATA 187 running with CUCM 7.1.5....I can receive FAX without any issue, but unable to send FAX at all....Why that so?? Is that a bug with ATA 187?? Can someone guide me...
Subject | Author | Posted |
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM | ||
06-30-2025 02:50 AM |
User | Count |
2 | |
2 | |
2 | |
1 | |
1 |
