Per call load sharing on CUBE
KY_
Level 4
Level 4
Hi Dear,
I have a question about  CUBE, How can I load sharing with per call on CUBE
For example I have two dial  peer different session target I want to route to one calls different ISP one call  another ISP... (First call call should be route ISP A the second call should be route ISP B )
How can proceed it ?
5 Replies 5
Manish Gogna
Hi Kemal,
Please check the following post with similar query
https://supportforums.cisco.com/discussion/10644386/voip-dial-peer-load-balancing
Manish
Hi Manish
ı checked it before but its not answer my question.
I want to do this ,
First cal should be  route ISP a, second call should be ISP B and third one is come back again ISP and A  another one  shoul be route  ISP B.
That mean every one call should be match one by one different ISP.
If i use without preference command it will ve select randomly do it.
That is correct, in this case the dialpeer selection would be random.
But you can add the below command.
dial-peer hunt 1
Which means <<1 - Longest match in phone number, explicit preference, least recent use>>
After this, the calls will match the two dial peers alternately.
So for your current requirement you can do the following.
1. Remove preference commands from both dial peers
2. And then add the dial-peer hunt 1, this should make the call to match both dial peers alternately
You may test this and let us know if it works.
Manish
In my scenerio , what should it do ?
Is following configuration correct ? Firs cal should be match dp 2 second call should match dp 3
I checked that but dial-peer hunt is different thing as my question.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_d1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1100737
dial-peer voice 2 voip
 destination-pattern 55555
 session protocol sipv2
 session target ipv4:2.2.2.2
 voice-class codec 2
 dtmf-relay rtp-nte
dial-peer voice 3 voip
 session target ipv4:1.1.1.1
 voice-class codec 1
 dtmf-relay rtp-nte
igor_ye
Hi Kemal
You can do this with voice class server-group with round-robin hunt scheme.
For example
voice class server-group 1
 ipv4 <ip ISP A> preference 1
 ipv4 <ip ISP B> preference 2
 hunt-scheme round-robin
 session server-group 1
 voice-class codec 2
 dtmf-relay rtp-nte
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/dialpeer/configuration/15-mt/vd-15-mt-book/multiple-outBound-dial-peer.html
