05-14-2013 01:16 AM - edited 03-16-2019 05:18 PM
Hi again cisco techs,
Thanks to Jamie Valencia and other helpful respondents to my previous questions.
Upon executing
archive tar /xtract tftp://ipaddress/filename.tar flash:
to transfer cme file to 2691 router, I get
Permission denied.
Using tftpd32 for this. IP address, DNS, etc are allocated to cisco phone.
Admin level is 15.
File is 65 mb compressed holding cme 4.3.
Router has 128 memory.
TFTP address is same as DHCP
Router can ping TFTP server ok and DNS too
Any thoughts are appreciated.
Thanks again in advance.
Solved! Go to Solution.
05-15-2013 11:48 PM
Hi John,
Just I was thinking , u can do ftp [first copy file to router ] and then, install.you can use Microsoft ftp or google for any free ftp .
after TAR file is copied on the router and then, you can extract.
please refer this Youtube link
http://www.youtube.com/watch?v=b5nXCvTharM
regds,
aman
05-14-2013 01:26 AM
Hi John,
Can u cross-check whether tar file is stored in location where tftpd32.exe is installed ?
secondly, any windows firewall is installed on PC which is blocking tftp.
regds,
aman
05-14-2013 01:50 AM
Thanks for your response Amanso.
You mean the base or current folder directory?
Windows firewall is disabled ATM.
05-14-2013 01:53 AM
Hi John,
Suppose u have a TFTP folder which has this tar file along with tftpd32.exe stored/executed in this folder.
regds,
aman
05-15-2013 04:08 PM
Thanks for the reply Amanso,
Unfortunately this hasnt worked.Any other ideas if you have are appreciated.
05-15-2013 04:43 PM
Hi John,
Try this:
First transfer the file from TFTP32 to CME, second extract the file from CME.
Sometime is better do the job step by step
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
05-15-2013 04:54 PM
I am no CME guy but I have seen that error message before.
1. Check the original file for permission. Make sure it's enabled read/write;
2. Check the directory of the router and make sure there's no other subdirectory, like "update".
NOTE: John, please delete your other thread about the same topic. This minimizes confusion for everyone.
05-15-2013 10:13 PM
Thanks leolaohoo,
Deleted other thread. Will try your points tonight..:)
05-15-2013 11:48 PM
Hi John,
regds,
aman
05-20-2013 06:33 AM
Hi Amanso,
Tried your weblink. Still access denied. Unfortunately. Downloaded FileZilla Server. Followed directions in video. Still access denied. I also noticed that when I upgraded the flash memory to 256mb. Repowering router shows
Warning:flash:flash does not exist. Command not retained message.
sh ver gives this output...
cme_router#sh ver
IOS (tm) 2600 Software (C2691-IS-M), Version 12.2(13)T1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 03-Jan-03 15:53 by ccai
Image text-base: 0x60008940, data-base: 0x6198A000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
cme_router uptime is 24 minutes
System image file is "flash:c2691-is-mz.122-13.T1.bin"
cisco 2691 (R7000) processor (revision 0.1) with 111616K/19456K bytes of memory.
Processor board ID JMX0642L246
R7000 CPU at 160Mhz, Implementation 39, Rev 3.3, 256KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of non-volatile configuration memory.
31296K bytes of ATA System CompactFlash (Read/Write)
0K bytes of ATA Slot0 CompactFlash (Read/Write)
Searched the cisco forums for info but only found this below link for flash error message...
05-20-2013 06:41 AM
Hi John,
Please format the flash which u have inserted externally in Slot 0 .
Please try .
regds,
aman
05-21-2013 05:10 PM
Hi Amanso,
Your youtube solution kind of worked but apparently I ran out of space. But I had a 256 mb flash memory. And compressed file size is 77mb.. i dont understand?
05-22-2013 01:27 AM
Hi John,
Can u cross-check size of flash in slot 0: ?
Also,please share the exact error message which u get ?
regds,
aman
05-22-2013 05:47 PM
Hi Amanso,
Thanks for your help again.
Checked forums for varied ways to check flash memory..only found standard commands. How do you do this please?
Done search via google but as this was more specific to slot0 on router, didnt conclude anything.
The 2nd answer is displayed in my new discussion thank you.
05-22-2013 08:13 PM
Hi John,
Please issue the command dir slot0: and provide th eoutput.
or if possible, provide show tech of router.
regds,
aman
